dot 5 brake fluid
Old May 26, 2010 | 01:37 PM
mag11581's Avatar
mag11581
Default dot 5 brake fluid
i'm planning to put chrome master cyl and braided brake lines on
my 2010 fatboy.
should i leave the dot 4 brake fluid or should i refill the system with
dot 5 ?
Old May 26, 2010 | 01:40 PM
DaFish's Avatar
DaFish
Re-fill with the same type of fluid that came with the bike unless you change out all parts of the system.
DaFish
Old May 26, 2010 | 03:33 PM
0734's Avatar
0734
Yep...it would be best to put in what came out, but I don't always play by those rules. If I do a major brake repair like new lines.....I swap over to 4. Arguments abound concerning the pros-n-cons of DOT 5 vs. the glycol based (3, 4 and 5.1) fluids and each one has it's advantages and disadvantages. You can go "read-up" on the internet and discover for yourself the differences. The biggest advantage people usually like is that the DOT 5 won't harm the painted surfaces, but if I spill anything on my paint...be it 5, 4, oil, transmission fluid or beer...I am going to clean it up right away anyhow. 4 is much cheaper and much, much easier to find.
Old May 26, 2010 | 03:35 PM
0734's Avatar
0734
Oh....let me make sure and second DaFish's motion....DO NOT MIX THEM.
Old May 26, 2010 | 03:53 PM
mag11581's Avatar
mag11581
i googled it. kinda makes your head spin.
the only real answer i could come up with is that dot 3, 4 and 5.1 are glycol based and dot 5 is silicone based. lol
i know not to mix glycol with silicone, i would purge the lines and put all new fresh. just cant get a handle on which is better.
i guess i'll just stick with what willie g put in at the factory.
Old May 26, 2010 | 03:59 PM
Tucson_Tim's Avatar
Tucson_Tim
Hasn't H-D gone back and forth with what they use? DOT-4 to DOT-5 and back to DOT-4?
Old May 26, 2010 | 04:09 PM
mag11581's Avatar
mag11581
yep, thats one of the things that is confusing.
after a quick scan of other threads( both here and on other hd forums) ,
i aint the only one confused! seems h-d is too.
Old May 26, 2010 | 04:59 PM
rh8234's Avatar
rh8234
Dot 5 doesn't destroy the paint if you spill some. All the others do. I THINK - BUT AM NOT SURE - Dot 5 also does not absorb water like the others. DO NOT MIX DOT 5 with any others. They do not get along well.
Old May 26, 2010 | 06:00 PM
0734's Avatar
0734
Guys...I swear that I am not trying to argue one way or another, because either works just fine. Harley has switched back-n-forth and I think you HAVE to use DOT5 in the ABS brakes (not sure).
I have done a good bit of research and I prefer the DOT4 because it is easy to find and is not nearly as expensive as the DOT5. The difference in the money doesn't matter a great deal as brake fluid is something you don't change every day. I have cut a rear brake line out in the middle of nowhere and not a drop of 5 could be had at any auto parts store.....3 and 4 are everywhere.
DOT5 does not absorb moisture, but the moisture will still enter the system, find a place to puddle-up and cause corrosion. It is recommened to change DOT5 on a more regular schedule than any of the glycol based fluids....like annually. DOT5 is suppose to be paint friendly, but you'd wipe anything off your bike that got on there anyway, so that does not matter a lot to me either...just for that advantage. DOT5 does have a higher boiling point....but ask yourself...do you race this thing or ride it for pleasure. DOT5 is also more compressable than DOT4, but that does not matter most of the time. For lots of reasons...DOT5 is not necessarily a superior fluid.
DOT 3, 4 and 5.1 are glycol based and will mix with each other (although I would only use the 4). The 5.1 is just a glycol replacement for the higher boiling point of the DOT5.
I routinely replace 5 with 4....but DON'T MIX the two. You can bleed a couple of bottles of 4 through the system and then run the 4....IF you want to.
Old May 26, 2010 | 06:12 PM
Tucson_Tim's Avatar
Tucson_Tim
Default FYI - 08 Softails use DOT-4
FYI only . . .
For those interested, my 08 H-D Softail service manual states DOT-4.
(I wasn't sure because my 04 XL1200R uses DOT-5, I believe).
