Dual disc hub conversion question
Old Nov 6, 2011 | 12:10 AM
harley rancher's Avatar
harley rancher
Default Dual disc hub conversion question
Sorry if this has been addressed before haven't really found any info. Can I use a dual disc hub from a factory 16x3 wheel to convert my 04 softail 21x2.15 wheel to dual disc?
Old Nov 6, 2011 | 12:24 AM
harley rancher
I knew if I asked a question asking for help I would find the info. on the web. The way I read it, it will work.
Old Nov 6, 2011 | 12:26 AM
BrianG's Avatar
BrianG
Yes, you just have to figure out the right length of spokes, and then find someone to lace it.
Old Nov 6, 2011 | 07:55 AM
harley rancher
Thanks for the help Brian. I will buy the 16x3 wheel so I can use its hub.
Old Nov 7, 2011 | 12:47 PM
grbrown's Avatar
grbrown
Cool
All you need is an expert wheel builder, who will magically supply the correct spokes and give back a built wheel. Much simpler......
Old Dec 1, 2011 | 11:56 PM
BrianG's Avatar
BrianG
Or you can do what I did and get a wheel from a Touring model and mount it up as it is, but that won't be a 21" wheel. They are dual flange hubs to start with.
There may be spacer issues to resolve due to the new hub size and the installation of the Touring lower fork legs you are going to need as well.
You can use the older 16X3 ones or get a newer 17X3 unit. Depending on your year and that of the wheel you may have bearing/axle size issues but that's not a difficult fix. The axles went from 3/4" to 1" to 25mm but they all had the same 52mm outside diameter so it's just a matter of replacing the bearings and internal spacer.
StreetGlide23
Dec 4, 2017 01:40 PM
hdjoe79
Trikes, Hacks and Trailer Parts
Jul 17, 2014 06:54 AM
ShovelGearBanger
Wheels/Tires
Apr 4, 2012 12:01 PM
kingofsand21
Feb 10, 2010 10:41 PM
09DynaMan
Sep 3, 2009 06:50 PM
