Softail rear axle
Old Dec 14, 2011 | 11:03 AM
Mike74's Avatar
Mike74
Default Softail rear axle
I have a 92 Sofatil that someone has flipped the axle on, so it goes through from the left side. I want to mount an axle tag bracket to it so I have to remove the axle completely and was planning on putting it back through from the right side since my exhaust will no longer interfere with it that way. Local bike shop wants 1.5 hours of labor to do it and I think that is ridiculous. Anyways, I dont have a bike lift or jack so my question is this:
Can I leave the bike sitting on the kickstand and slide the axle out and flip it and slide it back in?
I have never worked on a bike so I want to make sure the wheel isn't going to go anywhere and my friggin bike fall.
Thanks
Mike
Old Dec 14, 2011 | 11:14 AM
Big Trev's Avatar
Big Trev
No you defiantly need a jack,I have used a trolley jack with the bike on the side stand, not ideal but it's ok if you are careful,+ a torque wrench to re-tighten the axle
Old Dec 14, 2011 | 11:19 AM
Mike74's Avatar
Mike74
Cool, thanks.. Guess I will see if I can locate a jack now..
Old Dec 22, 2011 | 02:13 AM
grbrown's Avatar
grbrown
Wink
All you need is a scissor jack, the sort of thing that comes with some autos. Lift under the rear of the frame (put a piece of card between it and frame, to save the paint) and gently lift until the tyre is only just touching the ground.
Loosen all nuts before lifting the bike, then you should be able to slide the axle out and back in, refit nuts, lower and remove the jack, then tighten up.
Old Dec 22, 2011 | 07:13 AM
Mike74's Avatar
Mike74
I appreciate gr, I havent tackled it yet, but I will.
Old Dec 22, 2011 | 09:09 AM
grbrown's Avatar
grbrown
Thumbs up
Sunday is getting a bit close for comfort! We have lots to think about around now......
Best of luck when you tackle it.
CoolBreeze3646
May 28, 2019 07:55 AM
mmstangs17
Oct 19, 2016 12:19 PM
Jmbeebe0722
Aug 9, 2013 09:26 PM
katanaplanet
Jul 19, 2012 02:53 PM
Noride
Screamin Eagle CVO Models
Oct 5, 2009 10:23 PM
