Wheel directional question
Old Jul 20, 2012 | 02:16 PM
ubreal's Avatar
ubreal
Default Wheel directional question
When my tires get worn out I take off the wheels and take them to the dealer to be change. This way I can look at the bearings and make sure everything is ok. This time I notice that the tire on the front wheel is going the wrong direction. Since I have duel brakes on the front I just spun the tire around so the left rotor is now the right rotor. In the manual it says not to do this, but that is with stock rotors. On my bike I have the floating rotors and there is no left or right rotor. Do you thing that this could cause a problem? The tire is going in the right direction and both rotors are the same I do not see any problems, the bike seems to stop good. But I am about to take a long trip and I do not want any problems.
Old Jul 21, 2012 | 06:10 AM
grbrown's Avatar
grbrown
A friend has just replaced his wheels and was surprised that brake rotor direction is so important for the stock rotors (with the curved 'spokes'). In your case I think you are right. I can't see any reason for the wheel to rotate in only one direction. Bearings are ambidextrous!
Old Jul 21, 2012 | 11:49 AM
Ridindirty's Avatar
Ridindirty
6th Gear
Hey Ubreal.. Only problem I could think would be your brake pads have bean worn a certain way, and when you switch the rotors, they will have to wear back down to fit the rotors. I would be carefully and not brake too hard when first switching sides as it might over heat the rotors and warp them. But besides this, I think your good to go! Hope this helps a little bit and makes sense.
Old Jul 23, 2012 | 02:46 AM
ubreal's Avatar
ubreal
I thought about the brakes and rotor thing to, I been braking slowly thanks for the concern.
Old Jul 23, 2012 | 06:02 PM
Ridindirty's Avatar
Ridindirty
6th Gear
No problem! Let us know if you run into any other problems.
Old Jul 23, 2012 | 06:37 PM
asm481's Avatar
asm481
You say the tire is now running in the right direction. Is this according to the tread and your assumption of how it should work or is it via the directional arrow on the tire sidewall? I'd be PO'd if a tech put the tire on backwards.
Old Jul 24, 2012 | 10:50 AM
killerrgu's Avatar
killerrgu
On my old fat boy they put it on backwards to stop a wobble and it worked.
blueduramax
Oct 10, 2021 06:31 PM
Mad Max 454
Sep 7, 2018 11:59 AM
Rain
Aug 12, 2014 08:01 PM
Allison Wunderland
May 16, 2014 07:19 AM
ubreal
Jul 23, 2012 04:27 AM
