2012 front wheel on 2004 roadglide
Old Aug 18, 2012 | 07:22 PM
04roadglide's Avatar
04roadglide
2nd Gear
Default 2012 front wheel on 2004 roadglide
2012 front wheel on 2004 roadglide.I was wondering if I can make this swap using a 25mm axle.
Old Aug 19, 2012 | 10:56 AM
grbrown's Avatar
grbrown
You should be able to swap your 25mm bearings for 1", so your axle etc works. However there are other things to check, like hub width and rotor diameter. Call over to the Touring forum and take a look through threads on doing this, it has been covered before.
Old Aug 19, 2012 | 12:45 PM
04roadglide
2nd Gear
Thanks for the info, just wondered because I have a 25mm axle and spacers. I will check the touring threads . Thanks again
Old Aug 22, 2012 | 10:57 AM
bigskyroadglide's Avatar
bigskyroadglide
i have a 2012 18 x 3.5 wheel on my 04 road glide. I converted to the 25 mm axle, got a flush mounted axle which worked great. i had to use the 08 up spacers. i did not use the 08 up rotors, but my old 07 down rotors. It works great. Once i do the brembo swap up front, i can convert the rotors to the new rotors, but that is another project.
Old Aug 22, 2012 | 04:42 PM
04roadglide
2nd Gear
Thanks bigskyroadglide, I thought it would work since the fork lowers are the same.
cmshdfx4
Oct 4, 2015 05:13 PM
jakespade
Jun 12, 2013 06:47 PM
bigskyroadglide
Oct 24, 2011 02:51 PM
JustDave71
Mar 28, 2010 12:43 PM
