Spacer question
Old Jun 2, 2013 | 07:38 AM
tattoofever's Avatar
tattoofever
Default Spacer question
So just got my wheel 3 wks after ordering I was told it would be bolt on right out of the box well it isn't. The spacer on the rotor side is about a 1/16 -1/8 to small
I have some big washers that are about the same width that I need to tighten things up can I just drill out the center hole to match the axle and use the washer ? I would keep the spacer on the bearing Side and put the washer on the fork side ,sounds easy enough is there any reason I shouldn't do this? Thanks In
Advance for any help
Old Jun 3, 2013 | 06:42 PM
02fx4dude's Avatar
02fx4dude
I used a shim between the spacer and fork leg on the rotor side of my low rider no problem, to be temporary until I get one custom machined.
Old Jun 4, 2013 | 01:24 PM
Hogpro's Avatar
Hogpro
Former Sponsor
What kind of wheel is it?
blksoftail
Feb 7, 2016 02:08 AM
OakBehringer
Sep 15, 2015 05:41 PM
larsfum
EVO
17
Jul 20, 2014 12:08 PM
06fxsti
Sep 22, 2010 09:14 PM
Budds
Wheels/Tires
Apr 26, 2009 05:47 PM
