Chrome calipers leaking
Old Oct 16, 2013 | 08:52 AM
customsoftail200's Avatar
customsoftail200
Default Chrome calipers leaking
I got a set of chrome calipers and I can't get them to quit seeping. There's not a drip but they are wet. They are as tight as I can make them, I took the calipers apart to check the seals, they look good. I checked to make sure there was no grit or anything under the chrome that wasn't allowing it to seal properly but that looked good too. I even went ahead and replaced the seals since I was there and it's exactly the same. A friend of mine bought chromed stock calipers from a chromer on eBay and his do the same thing.
Has anyone seen or heard of this?
Old Oct 21, 2013 | 07:08 PM
pastime's Avatar
pastime
I've been looking at those chrome calipers on eBay....they sure look sharp, but maybe not such a good idea? I'll be interested to see if anyone helps you out here. Best of luck!
Old Oct 21, 2013 | 07:46 PM
customsoftail200
I heard from a guy on the tourng model section that said his chrome Brembos did the same thing. He went back to stock and got chrome covers. I think that's the way to go or make sure they mask off the mating surfaces when they chrome. I think the tolerances don't allow for extra thousandths in plating and that's what causes the leak. I just picked up a set of stock black ones, I'll try to find some covers and call it a wrap..
Old Dec 5, 2013 | 05:27 PM
the warden's Avatar
the warden
I have a set of chromed Brembo's from an e-Bay vendor and have no issues in the 10k miles since putting them on. Always make sure to replace the brass banjo bolt washer every time you remove it. I have seen these sweat fluid when reused. And be sure to tighten the banjo bolt to the proper TQ spec as well.
Old Dec 5, 2013 | 05:30 PM
Hogpro's Avatar
Hogpro
Former Sponsor
I got a set from ***** Shiney and have no issues. I tend to agree that the extra thickness from the chrome is probably causing your issue. It might have to be thinned out a little on the edges where the calipers seal together.
Old Dec 21, 2013 | 12:02 PM
DanDman's Avatar
DanDman
I had a similar problem with some rocker covers I had chromed, and leaked bad. I took a close look and the mating surfaces had a slight lip and drips. I cleaned them up carefully with fine mill file.
Old Dec 21, 2013 | 12:21 PM
ROLLNTIGER's Avatar
ROLLNTIGER
That would be me and yes I tried everything. The clearance on the Brembo's is so close that I guess the chrome is just enough to make them seep.
Before
After
If anyone needs the right side I still have it... like new!
Old Dec 21, 2013 | 12:25 PM
ROLLNTIGER's Avatar
ROLLNTIGER
Mine were doing the exact same thing. No drips just constant seeping that I figured would cause further damage and braking issues over time.
Old Dec 22, 2013 | 09:37 PM
Sport Chrome's Avatar
Sport Chrome
Former Sponsor
Like someone mentioned above, I also think your issue is with the mating surfaces of each halve. There is a good chance that a small amount of plating in one area is causing them to not fit flush. If possible try rubbing them on a lapping block.
Old Dec 23, 2013 | 07:08 AM
1flhtk4me's Avatar
1flhtk4me
Take them apart and check for improper masking,burrs,dings and flatness of mating parts.
A small surface plate works great for checking flatness and lapping.
Steddy
Oct 29, 2014 12:05 PM
psidaho
Apr 26, 2014 05:08 PM
RidemyEVO
EVO
Feb 7, 2012 04:42 PM
bobby5
Jan 28, 2011 09:04 AM
Wally
Nov 18, 2005 12:12 PM
