• Added capability to view information about a point of Interest, H-D dealership, recent destination, saved destination, home, or XM fuel price station while in a current route
• Added capability to cancel "Next Waypoint"
• Increased waypoints to 100
• Fixed automatic screen brightness
• Fixed map zoom level
• Performance and stability enhancements
Read further along to find out update bugs and fixes
I went through all their products in all 3 categories they list & there's nothing that'll allow BT voice commands to HD's Infotainment system. If I missed it, please share the link. Thanks.
Two issues I've had through all updates are: 1. I mostly stream music from my iPhone via Bluetooth and every time I shut down, it always returns to radio, forcing me to go through the multistep process of launching streaming again, and 2. On multiple occasions and without warning, upon start up, I lost all of my XM presets which for some reason changed to WB presets. Forcing me to manually tune the XM stations then re-enter them as presets. So damn annoying. I would classify both of these issues as "stability problems" so I really hope this update addresses them.
I personally don't think a software update is going to fix the iPhone streaming issue without adding a significant delay to the radio start up time. I think the issue is that if the system takes too long to Bluetooth connect when it starts up it thinks the iPhone is disconnected and it defaults to radio. Mine does the same thing occasionally with the USB drive (especially if the USB is cold and the radio has been shutdown awhile). Sometimes when I have been listening to songs from a playlist and I shut the bike off, the next time I start it up the radio starts playing all the songs on the USB again instead of just the ones on the playlist.
Is there a trick to getting the radio to go to the next song in a USB drive? The "seek" or "next" button works when it's playing songs from my phone via blue-tooth, but not when playing songs from the USB.
HOME>MEDIA>MENU press the multiselect button to show SEEK and select that.
One bit of warning on the Sierra harness in it's current configuration, this only affects 2014-15 bikes. They have one harness for ####-present bikes and they have it listed as being plugged into the Passenger 7 pin and routed into the tourpak. If you do this you will lose use of the Voice Recognition system, it has to be plugged into the Riders 7 pin. Go plug your helmet into the riders port and hit the button on the left bars, you;ll hear nothing and it wont hear you.
As reported the Weather Map zoom works now, however it only has the full zoom and 3 levels of zoom-in which still shows a large portion of the state. I was hoping to zoom in to see where the rain begins/ends at the road level. The secondary roads don't even show up at the closest zoom level. Only the interstates.
I can't recall if there were more than 4 levels of zoom on the previous working version.
There were - it used to go (if memory serves, it has been a loong time since it worked) a couple more clicks in - you could get down to roads and see individual storms so as to split the rain
BINGO... You nailed it! That is exactly whats happening (I think) too. I've read this on other posts on here when the Rushmores first came out in late 2013.
