Cat Heat
Old Jan 25, 2015 | 12:35 PM
GroovusMagnus's Avatar
GroovusMagnus
Default Cat Heat
Does the catalytic converter produce enough heat to blue chrome?
I realize most bluing is caused by engine heat; I'm just curious if the cat does too.
GM
Old Jan 25, 2015 | 12:42 PM
p51bombay's Avatar
p51bombay
It does - around 900˚
Old Jan 25, 2015 | 05:50 PM
Gunnysgt's Avatar
Gunnysgt
The cat is designed to produce some heat. The O2 sensors are mounted there on the '10 and newer models. It's all part of the combustion regulation. As for flow, tests have indicated that flow is minimally effected on normal engines
Old Jan 25, 2015 | 06:01 PM
GroovusMagnus
I'm not worried about exhaust flow, and the heat hasn't yet been a problem. I'm contemplating slip-ons, and don't want to blow a lot of cash if the cat is going to blue them before I can replace the headers.
GM
Old Jan 25, 2015 | 06:08 PM
p51bombay's Avatar
p51bombay
the header will turn blue but the slip ones won't get hot enough to change.
Old Jan 25, 2015 | 06:09 PM
offthewall's Avatar
offthewall
Originally Posted by GroovusMagnus
I'm not worried about exhaust flow, and the heat hasn't yet been a problem. I'm contemplating slip-ons, and don't want to blow a lot of cash if the cat is going to blue them before I can replace the headers. GM
The Cat will not blue your slip ons. Having the wrong fuel mixture will discolor your slip ons. Just make sure you get a tuner of some sort and add the proper fuel.
Joe S.
Mar 12, 2014 10:32 PM
oricko
Aug 7, 2013 09:35 PM
papejr
May 26, 2012 02:04 PM
masterblaster
Mar 30, 2012 12:50 PM
Yasky1997
Feb 27, 2012 09:49 PM
