primary capacity
Old Mar 13, 2015 | 03:58 PM
  #41
Copyless's Avatar
Copyless
Originally Posted by 95ci springer
Not everyone has a jack to hold it straight up.
If a person didn't have a jack, or at least a helper to hold up the bike, then how would they service the primary? I guess I have always had some sort of jack, even if it was only one that I now use to lift the rear tire, so I have never even tried or even thought about it on any of my bikes (past or present), but I guess you can put in 38oz on the Jiffy stand?
Old Mar 13, 2015 | 04:16 PM
  #42
IUOE ROB's Avatar
IUOE ROB
I built a small "step" with a couple of 2x4's and a piece of 1/2 inch plywood, I put it under the side stand and it holds the bike almost level, not perfect but close enough. That's why I paid particular attention to how much oil I put in, exactly 38 ozs.
Old Mar 13, 2015 | 06:01 PM
  #43
skieverything's Avatar
skieverything
How about the scissor jack that is in your car or truck?? If I didn't have a motorcycle jack, I would place a few short 2x4's on the side opposite the jiffy stand and then scissor it up on the jiffy stand side until it's level. Or what Rob said , I'm sure works as well.
Old Mar 18, 2015 | 12:32 PM
  #44
BezerkoBob's Avatar
BezerkoBob
Originally Posted by hog.ryder
I don't put a measured amount in, I just fill to the bottom of the clutch basket.
+1 to that. That's how I have always done it.
Old Mar 18, 2015 | 04:24 PM
  #45
skieverything
Do you use this method with the bike sitting upright or on the side stand?
Old Mar 18, 2015 | 09:50 PM
  #46
Punjabi Rider's Avatar
Punjabi Rider
My Limited takes slightly more then the wife's limited low to fill to the bottom of the clutch basket but it is still around a quart slightly less or more.
Old Mar 19, 2015 | 01:54 PM
  #47
Jackie Paper's Avatar
Jackie Paper
Have you ever thought this may be due to parallax?
Parallax is a displacement or difference in the apparent position of an object viewed along two different lines of sight, and is measured by the angle or semi-angle of inclination between those two lines. The term is derived from the Greek word παράλλαξις (parallaxis), meaning "alteration".
Old Mar 19, 2015 | 02:34 PM
  #48
RG Pilot's Avatar
RG Pilot
Yes....that is exactly right. Closing one eye also reduces that effect.
Old Mar 19, 2015 | 02:35 PM
  #49
JimScharf's Avatar
JimScharf
Doesn't the Low have a slightly slimmer primary cover, thus affecting the capacity?
Old Mar 19, 2015 | 02:58 PM
  #50
SafetyMan's Avatar
SafetyMan
That was my thought.
