engine temp management system
Old May 24, 2015 | 09:05 PM
  #31
Onedef1's Avatar
Onedef1
Originally Posted by coinman
I just picked my new 15 RG up this afternoon. I was told that the EITMS literally shuts down the back cylinder when you are at a complete stop when it gets "hot". They never mention anything about at what engine/outside temperature it would do this at. I was also told as soon as you give it the least bit of gas the rear cylinder would kick in. I asked like when you're in bumper to bumper traffic, and he said only when stopped. He said something about the bike "running rough" when the rear cylinder has stopped. Can anyone trump the dealers statements?
I can vouch for that, mine first kicked in when temps outside weren't over 50... I noticed the odometer screen said it was active. It DOES start rough when you try to go...it does kick the cylinder back on but not real fast. You kind of spitter a little for a second.. As a solution I would give it a blip before taking off if it is active, that resolved the issue. I have since turned it off altogether.
Old May 25, 2015 | 07:49 AM
  #32
Schoondog's Avatar
Schoondog
Thumbs up +1 for this
This is exactly what I have found since August 20 2013 when I fired mine up. Always been this way with the Rushmores.
Originally Posted by SafetyMan
RTFM!
It comes on when AAT is above 80şF AND the bike has been running more than 4 minutes AND the speed is below 3 MPH AND engine at idle.
Old Aug 17, 2015 | 05:03 PM
  #33
TomWoodgeard's Avatar
TomWoodgeard
So.......Warming up the bike longer than 4 minutes is no longer needed??
I always used to start the bike in the morning for about 5 minutes then leave.
Everything change on the wet heads?
Old Aug 17, 2015 | 05:41 PM
  #34
kustom78's Avatar
kustom78
I never thought about it the way safteyman put it, makes a lot of sense tho. a regular air compressor will get scolding hot in 10 minutes. I'm convinced its BS and disabling mine. When its hot its hot, with or without it active it feels the same to me. Just another aggravation when it kicks in and having to turn it off when the light changes
Old Aug 17, 2015 | 07:10 PM
  #35
mchanu's Avatar
mchanu
In my experience the EITMS, even though sounding awful when active, works very well. The compressor analogy isn't completely accurate. Shutting down the rear cylinder eliminates the firing spark plug and fuel burn and thereby eliminating a 3-4 hundred degree rear cylinder from the system, including the hot exhaust gases. I was stuck recently in stop and go traffic for 45 minutes during an accident in 95degree temps. The shutting down of the rear cylinder made the episode very manageable. The heat reduction is very noticeable.
bmaier
2014-2024 Touring Models
28
Oct 2, 2016 07:49 AM
Louie-lou
Apr 16, 2016 02:44 PM
Calvert760
Mar 7, 2013 07:46 AM
1sweetglide08
Dec 19, 2012 04:41 PM
roadking1893
Mar 9, 2009 10:51 AM
