Outdoor Air Sensor? Worthless?
Old May 25, 2015 | 06:50 AM
14GuineaPig's Avatar
14GuineaPig
Originally Posted by WG2011
Thanks gents, I will check it out not sure what it looks like however
Read Post #25. It shows Service Bulletin M-1351. Look at Figure #1, it shows the location of the Ambient Air Temp Sensor.
https://www.hdforums.com/forum/new-r...-system-3.html
Old May 25, 2015 | 09:56 AM
WG2011's Avatar
WG2011
Well it must have been a fluke or something I see where the sensor is thx to the above poster and I did not mess with it at all I was thinking it was in the fairing somewhere. I will have to pay attention in my next ride when it gets decent out. Damn rain
Old May 25, 2015 | 10:40 AM
stubby001's Avatar
stubby001
I have found mine to be very accurate, much better than my 07.
Old May 25, 2015 | 10:48 AM
TriGeezer's Avatar
TriGeezer
My 2012 is generally more accurate than wetting my thumb and holding it out. But, not sure why I need to be more accurate than my wet thumb. Yep..it's cold out...yep...its hot out.
Old May 25, 2015 | 05:49 PM
WG2011's Avatar
WG2011
Went out for a 100+ mile cruise today and it was off by at least 10 degrees high. It seems like it's always at 77 degrees no matter what. I have seen it change but ever since I did the bars it seems off. Not sure what the bars had to do with it tho because that sensor is not near where I had to monkey with things.
Old May 27, 2015 | 06:08 PM
Punjabi Rider's Avatar
Punjabi Rider
This is the first Harley ever gives me accurate time, mph, odo and temp. It's on the left side on the goose neck you will see a wire connects to it from the front of the gas tank and other end has no wire just a little white nub. There should be one big wiring harness fiber sleeve and right underneath is temp sensor wire by it self in a split loom.
Old May 27, 2015 | 06:13 PM
jcapps's Avatar
jcapps
mine is pretty accurate
Old May 28, 2015 | 11:05 AM
WG2011's Avatar
WG2011
Well gents I did the boom audio system update and its either a coincidence or not but that seems to have fix the problem.
Old Jun 8, 2015 | 11:27 AM
rattracer's Avatar
rattracer
Mine is worthless. Always about 10-15 degrees too high. Anybody ever recalibrate one?
Old Jun 8, 2015 | 12:45 PM
WG2011's Avatar
WG2011
Similar here after the boom audio update it seemed to help coincidentally, but its still off by 5 degrees roughly.
bulldog485
Jun 4, 2015 08:38 AM
Arizona
Jan 22, 2014 12:52 PM
rlb5857
May 7, 2008 10:14 PM
gilbos440rt
Aug 1, 2007 06:59 PM
Cowboy49
May 26, 2007 10:50 PM
