Handlebar Install Problem
Picked up my tools and went for a ride. Got an error code; TGS1, TGS 2 and correlation. So I figured I would simply take apart again re-adjust the bars to perfection and see what I might have wired wrong. Went through everything checking continuity through each wire with no shorts or opens. After an hour I gave in and went to the dealer. They said they never use the same Twist Grip Sensor (TGS) and gave me a new one, well $110. Got home to find the connector on the TGS is male, which should have been female like the oem. Went back to the dealer because the part number on the box was also labeled for a 13 or older. They said that it was the correct one because this one doesn't have the green plug that can be a problem and I now needed to change the connector on the bike to female. So I bought that Molex connector, cut the wires on the bike to make female. Guessed a bit on the wire colors because there are no instructions for the new TGS or Molex connector. SM didn't show TGS wire colors.
All the errors are gone but one, the correlation error, which I hopefully will figure out but it does not seam anyone else is having this kind of problem to add bars. Its also very confusing to change the female on one end while changing the male on the other all while the new TGS wire colors changed. WTF, I cant imagine the dealer actually does this to every bar install like they suggested.
Any input would be helpful.
Thanks.
I don't think the wires to the new TGS are a problem cause if they were, you would have no or backwards throttle response (friend of mine did that - at idle throttle he had full and full throttle the bike would idel)
https://www.hdforums.com/forum/touri...-question.html
