Error message Sync failed
Old Aug 28, 2015 | 11:29 PM
Hammz's Avatar
Hammz
Originally Posted by Dsm Limited
In my case, the " sync failed " is due to text messages not syncing. My phone connected by bluetooth does everything that it is suppose to do, other than texts.
I can make & receive calls, play music, look at at my contacts. Texts won't sync or register. Although, I have been told how to get it to work. If you delete all of your texts from the phone, it will sync. MMS messages stop the sync from working. I'm just not willing to delete all my old messages.
Delete those MMS messages & it should sync. Keep the MMS messages & lose the text message option through the bike.
Old Aug 30, 2015 | 09:56 PM
clackavosticus's Avatar
clackavosticus
Smile I had the same problem
I had the same problem. Someone in the forum said it has something to do with some types of text messages you have stored on the phone. If you delete all your text messages (which will get rid of the problematic text message(s)) the sync issue will go away.
Old Jun 16, 2017 | 05:02 PM
pgkaylid's Avatar
pgkaylid
fairly simple fix, altho it took me a while to figure it out, on your i phone (i have a 6) go to your settings, then bluetooth, then under my devices find H-D Radio, click on info, and make sure that Show Notifications is ON. the default is off and mine went back to off after i needed to clear data and reset after a repair...
Old Jun 16, 2017 | 05:23 PM
Hammz's Avatar
Hammz
This thread is 2 years old. Check the date before offering a fix for a problem long resolved.
BTW - Welcome back to HDF!
sarpeezy
Oct 22, 2013 09:16 PM
Road_Hawg
Jul 15, 2011 02:16 PM
underdog2003
Nov 13, 2010 02:20 PM
Chicagosong
Jun 14, 2010 12:41 AM
AMISH OUTLAW
May 25, 2008 04:16 PM
