Calling all programmers
Old Feb 3, 2016 | 10:26 AM
Magnut1's Avatar
Magnut1
Default Calling all programmers
I am pretty sure this is do-able but would like some input from dealer mechanics. I bought a CVO complete dash from a 14 SERK and going to install on my 14 RK. Side by side the wireing looks pretty close except for some colors of wires. The SERK dash came with a proximity sensor (that is what I am calling it right now) where my original ignition switch. The connectors are different on the ignition wires so I made a jumper and it turned on with my ignition switch but had a VIN error on the display I believe the display (mph/tach/etc) is programmed to the VIN. So someone can't take one from a low mileage bike and put on their high mileage bike. What I am just wanting to make sure of, is if I ride my bike to the dealer with the orig dash, install it or have the dealer install it ,takes like 5 mins, (or 1 hour in dealer time) and be sure they can program everything up to my FOB through the BCM?
Anyone want to weigh in?
Old Feb 4, 2016 | 07:30 AM
TomboAT65's Avatar
TomboAT65
So Harley in their infinite wisdom decided to lock Speedometers to VINs. So even if you take it to a dealer you will still get the VIN error. Does the same when you buy a new gauge, after like 100 miles the speedo locks to that bike.
Old Feb 4, 2016 | 07:49 AM
mjohnson68's Avatar
mjohnson68
If you buy a new gauge it locks to the VIN after 33 miles. I replaced mine with CVO gauges and the do a 33 mile countdown on the trip meter.
Old Feb 4, 2016 | 08:46 AM
RollaMo's Avatar
RollaMo
Pretty much all manufacturers do this these days.
How dare them try to prevent odometer fraud.
Old Feb 4, 2016 | 09:04 AM
TomboAT65's Avatar
TomboAT65
While I get the odometer fraud part. But the odometer reading on the canbus bikes comes from the ECM not the gauge itself.
Old Feb 4, 2016 | 10:56 AM
Magnut1's Avatar
Magnut1
Did you buy new or used? I got the vin error and wonder if I drive it 33 miles would it marry to my vin?
Old Feb 4, 2016 | 11:16 AM
TomboAT65's Avatar
TomboAT65
Is it new or used?
And I hate to say I may have been mistaken due to previous experience with Harley gauges. When I swapped my Street Bob gauge it locked in the mileage from the ECM. But I cant verify the new touring bikes do the same.
Old Feb 4, 2016 | 11:21 AM
Magnut1's Avatar
Magnut1
It is used, and has the proximity sensor in place of ignition switch. Different plugs so I jumpered my ign switch to the CVO harness and it did turn on, would start but had the VIN ERR on the display.
Old Feb 4, 2016 | 11:50 AM
TomboAT65's Avatar
TomboAT65
Yea might have an issue getting the dealer to connect it to your bike, being that it is used.
Old Feb 4, 2016 | 01:46 PM
GlidingJoe's Avatar
GlidingJoe
There were previous threads of folks swapping out CVO gauges and such and they all found that they needed to purchase new Speed O gauge, all others can swap but that one locks to the ECM and can not be changed.
