Maybe there's a bird living on top of one of the cylinders. But seriously, does the chirp happen just holding the revs at 3,000. Or does it just occur under load ? I had a bike several years ago that kind of made a chirping noise at 3,000 under load. On that bike it turned out to be the primary chain , needing adjustment. But the Rushmores have a self adjusting tensioner .
Friend of mine had that problem back in 2009. Come to find out his rear tire/sprocket was slightly misaligned and apparently the belt was causing the noise. Worth checking anyway.
The first thing to do as to spray some lube on the front top engine stabilizer link to see if you loss the chirp. I now add a couple of drops of 3-in-1 oil to the top link after it drove me nuts.
does this chirp happen when at a speed or any time the engine hits 3000? At that rpm the engine should be running smooth. I would figure a lower idle with the engine running rougher would cause the mounts to be the problem. Could it be pinging? What grade fuel are you running?
I had a chirping sound with my 2008.
It turned out t be the muffler. I loosened the muffler and gave it a slight twist and the chirping went away. Hope this is your issue because it is an easy fix.
