Supershox feedback
Old May 23, 2021 | 06:35 PM
Gorion's Avatar
Gorion
Veteran: Coast Guard
Default Supershox feedback
Been researching shocks for my ride. I see legends, progression and Ohlins discussed a lot but I’m leaning towards supershox. Anyone have/had them loved them hated them? Looking for real world experience before I drop cash.
Old May 23, 2021 | 07:02 PM
mkurup's Avatar
mkurup
I have a set that is supposed to be delivered this week, and I will be installing them on my 2020 RGS. I will be happy to let you know how it goes. I had Ohlin's on my last Harley, so we will see. The interaction when ordering seemed fine, and I got all of my questions answered by the owner on a phone call.
Old May 23, 2021 | 07:12 PM
Gorion's Avatar
Gorion
I would love to hear your thoughts 👍
Old May 23, 2021 | 08:56 PM
18 Wicked Special's Avatar
18 Wicked Special
I put the Sipershox 14" premium lt w/lowering blocks on my Road Glide Special last year, and it was night and day difference from stock. Gained 2" of travel over oem lows. The adjustment scale is easy to read and the ride is smooth. Quality built product with spherical bearings on the ends, not to mention made in the US.
Old May 24, 2021 | 08:26 AM
mkurup's Avatar
mkurup
That is the same setup I have on order...looking forward to it. I hope the change I feel is as pronounced as you describe!
Old May 24, 2021 | 08:44 AM
tpcowfish's Avatar
tpcowfish
I put them on my old bike ,14 limited, I had to do the front end after, but I liked them, very good customer service also, I don't have anything to compare them to, besides stock, but way better than the stocks, I really felt like it was more stable in turns also,
Old May 24, 2021 | 09:46 AM
Gorion's Avatar
Gorion
Sent supershox a request for a quote. Thanks for the responses so far.
Old May 26, 2021 | 07:22 PM
BigDawgQC's Avatar
BigDawgQC
Take a look at Wilbers too.
https://wilbersusa.com/wilbers-ldc-s...le-suspension/
Old May 26, 2021 | 07:35 PM
Illinois_Minion's Avatar
Illinois_Minion
Had 13" Premium LT w/lowering block on my '16 RGU. Absolutely loved them. Will drop the coin once i have it saved up, for the new bike.
Once dialed in (only a turn or two off) it was absolutely worth it,.
Old May 26, 2021 | 07:43 PM
mkurup's Avatar
mkurup
My 14 inch Premium LT's with lowering blocks will arrive Friday according to UPS ...I will install them and provide some more feedback next week...
Some info I received after my inquiry:
The Premium LT with 3-1/2" of travel order # SR2-34030 (part # SR2-3140-35-10-21) which comes with the relocation mounts that will have the same ride height with 1-1/2” more travel than you have now. Ride quality and comfort is absolutely amazing with these shocks and the best choice for solo or 2-up loaded or not. You will also feel a huge improvement in handling as the shocks keep the tire connected to the road.
Super Shox are a great value for a 100% Made In America shock with race quality internal components that are backed by a lifetime guarantee. We are so confident in our product that we offer a 30 - day money back guarantee!
Here are some reasons to choose Super Shox:
  • Impressive ride quality backed by customer reviews
  • Easy to set and adjust with a numbered scale
  • 2x more options based on rider weight than any other brand
  • Longest travel for a Bagger
  • Lower ride height options with increased travel
  • Spherical Bearing Ends that eliminate misalignment for a long life
  • Fully serviceable
  • 100% Hand assembled dyno tested and tuned
  • CNC Precision Machined in our shop located in Grayslake IL
  • Made in USA since 1997
  • 30 Day Money Back Guarantee
  • Lifetime Warranty
  • Great customer service and support
Super Shox are a suspension investment that make a difference every mile you ride. The shocks can be re-sprung, re-valved at any time or just serviced. Every shock we build is serial numbered, dyno tested and saved in our data base. With this data we can always check and service any shock and match them to the original spring and damping rates.
  • Shock check and service rate is $75.00 per set
  • New Springs are $90.00 per set
  • Re-valving is $100.00 per set (includes check and service)
Super Shox are a long life product with over 100,000 miles on test sets and no signs of wear or degraded performance. We use a high quality oil that prevents wear and improves heat dissipation. All parts are CNC machined to exact size and tolerance to have a perfect fit for long life and precise control over shock valving. Springs are made from the highest grade steel and processed to extend spring life. All parts are replaceable for a 100% serviceable shock.
Super Shox Life Time Warranty covers all manufacturer defects for the entire life of the shock. This stays with the shock even if the owner is not the original purchaser. Not covered are seal failures related to damage such as the shaft surface or excessive dirt build up. Damage to the shock body, Springs, Spherical Bearings, Dust Cover wear.
