2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Jun 27, 2019 | 11:49 AM
  #1601
Hardcase61's Avatar
Hardcase61
Originally Posted by LH1965
Yes mine leaks like nobody's business. Winter project is to replace with hard bags of some sort. These are a real piece of crap, IMHO.
Open up the bags and tighten the locking ring on each lock, this is usually where the bags leak
Old Jun 27, 2019 | 01:24 PM
  #1602
KMBike's Avatar
KMBike
Originally Posted by TxSpeedster
I pried the locking rings off the mounting studs to remove reflectors, then used automotive panel fasteners from Ace hardware to cover the holes in my saddlebags. They just push into the holes left when reflector is removed. The reflector imprint marks will vanish over the span of a few weeks. Several Heritage owners here have done the same.
Thanks a lot.
Old Jun 28, 2019 | 11:28 AM
  #1603
TxSpeedster's Avatar
TxSpeedster
Stage II Torque Cam: 96HP/114TQ
I was a bit disappointed with the peak numbers until I realized the torque was basically a flat line from 2,000 to 5,000 RPM. This thing never seems to run out of grunt and the idle is now music to my ears. Seems a bit more authentic. Very happy on the ride home!
Old Jun 28, 2019 | 12:55 PM
  #1604
Thingfish's Avatar
Thingfish
It will also significantly improve with about 500 mile break in. The new cam needs to wear a bit and the ECM needs to learn your ride style. Mine initially felt a bit of drop off around 4,000 rpm, but after a few hundred miles it stretched to 5,000 easily. Love this cam.
Old Jun 28, 2019 | 01:37 PM
  #1605
Phil13's Avatar
Phil13
Are you two discussing the Screamin Eagle torque cam? As in the SE8-447. I hope so as I'm just weighting up the pros and cons of it along with S&S tappets and quickee pushrods.
Old Jun 28, 2019 | 05:53 PM
  #1606
Hulkss's Avatar
Hulkss
I had my new 2019 Heritage 114 tuned with the H-D 447 torque cam, stock Ventilator air cleaner, S&S EPA legal slip-ons (high flow catalytic converters and sound baffles in place), H-D Pro Street Tuner, H-D Automatic Tuning Module with Wide Band Lambda (O2) sensors.
I do believe the H-D wide band tuning module allows more range of tuning adjustment to the dyno operator and better control of the engine fueling. This set-up is fully warranty and EPA legal.
SAE correction: HP 102, TQ 118; with STD correction: HP 106, TQ 123
The driveability and response of the bike is amazing. Never had anything run this well.
Old Jun 28, 2019 | 09:10 PM
  #1607
TxSpeedster
Nice numbers. I’ll be riding mine for a bit before getting a full dyno tune. The tech just did a quick dyno run after the cam and pro street tuner were installed. Everything save the Rineharts are Screaming Eagle and fully warranted. After hearing the Rineharts vs Street Canons I went for the sound!
Old Jun 29, 2019 | 12:09 AM
  #1608
Hulkss's Avatar
Hulkss
If the Rineharts do not have catalytic converters in them they are not EPA legal. Non-EPA compliant parts void your powertrain warranty.
Old Jun 29, 2019 | 01:02 AM
  #1609
Phil13's Avatar
Phil13
That is very impressive. Mind now made up!
Old Jun 29, 2019 | 01:51 AM
  #1610
Thingfish's Avatar
Thingfish
I think you’ll be happy. And yes that’s the cam we were talking about earlier.
