I promised that I would have lots of questions and heres my first one.....
. I want to change the seat on my new FLHCS to a solo seat and I am debating between the Mustang and the Ultimate. I have had both on other bikes and enjoyed them about equally.
i have long legs and have made use of extended brake and shift levers on previous bikes. I know from the Ultimate website that their seat puts you in the same riding position as stock which means I need the extended levers but I have read on this thread that the Mustang sits you further back from stock which may avoid the need for extended levers. I have also read on other threads that the Mustang moves you further forward but I think this was on pre 2018 bikes.
Can someone who has a Mustang solo please confirm the riding position?
I am am also interested to know if the Motherwell solo rear rack fits OK with the Mustang solo.
Thanks
I have mustang solo with Motherwell rack and like both very much. I have a 34 inch inseam and did not need any additional foot or handlebar control modifications.
K
Thanks for the info bird
Harley has been using this seat mounting system for 15 plus years. I think the only difference is the retaining washers are thinner and cheaper and don't hold as well. Much like the thinner fenders.
A good thing is you can push the studs through and put on a one piece seat.
Yes, and its stuff like this that kept me riding my old bike for so long. It just felt better thought out in many way. Or maybe I was just used to it.
H-D should take a page out of the Indian Scout seat attachment/latch design book. Rear of the seat has a keyway that sets on a stud mounted to the frame, then slides forward a bit so the key way prevents the rear from lifting. Front of thee seat has a stud that locks into a receptacle l on the frame with only a a slight downward pressure. To remove the seat, lift front tongue to disengage from the receptacle and slide the seat rearward to disengage the keyway. Take about 2 seconds to install or remove, no tools required....easy peezy.
Paul
Sure it's easy peasy, but is it lemon squeezy? Because without the lemon squeezy, I question the easy peasy.
sorry, I don't under stand the 'lemon squeezy' comment, explain please..... Thx.'
Paul
Sorry, bad joke - I was trying to be funny. Sometimes people add the lemon sqeezy to the other part - from the interweb: Easy peasy lemon squeezy is an elaboration on easy-peasy, likewise meaning extremely easy or simple. One of the earliest documented instances of easy-peasy appears in the 1940 American film The Long Voyage Home, used to advise a character to handle a suspicious box with care.
