2018+ Softail Models Breakout
The Everything 2018+ Heritage Thread
Old Jun 1, 2020 | 08:10 AM
  #2321
Uncle G.'s Avatar
Uncle G.
Originally Posted by Steve Sportster
3/8-16. Check length when you take out the original ones. I used stainless steel bolts. I ran a thread die onto them and ground a taper on the end for ease of alignment when reinstalling the bolts after a cleaning (etc). The die helps keep the threads straight. I never have trouble getting them out and back in.
I also ended up running a 3/8-16 tap through the nut plates To clean out the excess threadock goop Harley-Davidson used. Otherwise it was difficult to get the bolts back in without cross threading them.
Old Jun 1, 2020 | 10:15 AM
  #2322
Herbkell's Avatar
Herbkell
cross threading - unfortunately “been there done that”. It was a complete pain in the ***
i wish there was a quick release option
Old Jun 1, 2020 | 10:33 AM
  #2323
Herbkell's Avatar
Herbkell
Default Saddlebag quick release
Do you think something like this (in the correct size) would be an option?
Old Jun 2, 2020 | 02:40 AM
  #2324
Phil13's Avatar
Phil13
I would have thought that would be ok, if used with a suitable spring washer
Old Jun 2, 2020 | 09:52 AM
  #2325
Burbur2's Avatar
Burbur2
I like this idea. Please keep us posted where we can buy this bolt I might try this
Old Jun 2, 2020 | 09:53 AM
  #2326
Burbur2's Avatar
Burbur2
where did you find it? Any chance you can share the link or name for this?
Old Jun 2, 2020 | 10:21 AM
  #2327
OldMike's Avatar
OldMike
Lowes sells those or on line.
https://www.amazon.com/JW-Winco-Plastic-Threaded-Diameter/dp/B00A9N54FE/ref=sr_1_1?dchild=1&keywords=3%2F8-16+plastic+****+bolt&qid=1591111092&sr=8-1 https://www.amazon.com/JW-Winco-Plastic-Threaded-Diameter/dp/B00A9N54FE/ref=sr_1_1?dchild=1&keywords=3%2F8-16+plastic+****+bolt&qid=1591111092&sr=8-1
Old Jun 2, 2020 | 10:29 AM
  #2328
Herbkell's Avatar
Herbkell
https://www.grainger.ca/en/product/S...-16/p/WWG3GEW9
I found this one at Grainger but the longest they seem to sell is 1.5 inches. I think the one OldMike posted above is 2 inches. I don't have my bike handy but I think the OEM bolts are 2.5"
Are we on to something here? I would love a true quick release for the saddlebags. i suspect hand tightening would result in less cross threading which I know a few of us have experienced
Old Jun 2, 2020 | 03:39 PM
  #2329
Steve Sportster's Avatar
Steve Sportster
I just use a socket and a ratchet on the hex head bolts. Quick enough for the few times a year I take them off/on and a heck of a lot better than a Torx.
Old Jun 2, 2020 | 04:05 PM
  #2330
Hlgsn1's Avatar
Hlgsn1
