2018+ Softail Models Breakout
T-45
Old Aug 12, 2019 | 10:15 AM
Griff012FLHX's Avatar
Griff012FLHX
Default T-45
I have looked all over and I can't seam to find a T-45 socket that's 3" or 4" long....Need it for the passenger foot pegs..on my 19 Slim.
Old Aug 12, 2019 | 11:21 AM
Bowhunter8607's Avatar
Bowhunter8607
Google search brings up a ton of options. Harbor Freight has some as well. Not the greatest best brand name but are inexpensive and will do the job.
Edit: I thought I had got mine at Harbor freight but I now remember that they only had large sets which I didn't need. I ended up buying mine at Autozone because they had a set of 4 which were sizes I had a need for.
They are Duralast and are 3" long up to where the socket flares out and worked fine on my passenger peg mounts.
Old Aug 12, 2019 | 05:24 PM
Griff012FLHX
I just went to HB freight and none there....
I'll give auto zone a try....
I also tried Amazon and found nothing....I'll look again.
Oh..and thank you....
Old Aug 12, 2019 | 05:34 PM
DonN's Avatar
DonN
I bought mine on Amazon. Note that I broke it. The passenger pegs are on with super loctite. Use heat and impact hammer. I just took mine to dealer as had some other service to do.
Old Aug 12, 2019 | 05:56 PM
vynnski's Avatar
vynnski
Tried a socket extender?
Old Aug 12, 2019 | 08:43 PM
Bowhunter8607
Doesn't work. The socket portion of the Torx socket doesn't fit inside the peg mount to allow the Torx to reach the bolt head.
Old Aug 13, 2019 | 07:13 AM
AJ88V's Avatar
AJ88V
I used the $17 kit recommended in this thread
https://www.hdforums.com/forum/2018-...-softails.html
Use a long breaker bar instead of the standard ratchet so you can smoothly apply more torque. Those star bits strip too easy if you don't hold the wrench straight when you're applying a lot of force.
Old Aug 13, 2019 | 07:34 AM
OldMike's Avatar
OldMike
I knock the bit out of the socket and use it in a 1/4" drive, like this:
Old Aug 13, 2019 | 09:29 AM
Bowhunter8607
Good Idea! I would have done this but the only Torx sockets I had at the time are one solid piece.
grimFXDB
Apr 21, 2016 01:16 PM
T Smith
General Topics/Tech Tips
Jan 14, 2014 08:16 PM
Joltergeist
Mar 11, 2013 06:47 AM
christian0632
Oct 11, 2007 03:04 PM
humpyy57
Jul 7, 2007 10:04 PM
