2018+ Softail Models Breakout
Tapping from engine under load
Old Sep 30, 2019 | 03:20 PM
Puddle63's Avatar
Puddle63
6th Gear
Default Tapping from engine under load
Brought a new breakout 114 FXBRS two weeks and two days ago had done 460 miles on her keeping her below 2500 revs May have hit 3000 once or twice, my story starts on my first ride home, was a knocking. Kind of a sowing machine noise while moving (under load) a told Harley several times and all I got back was yeah they do that !!! That’s my new bike I’m thinking, anyway this gos on and I make more calls to Harley with Same response till last sat afternoon I go out for a ride and start her up, poof a big cloud of smoke and a smell of oil, so I rig Harley and they say call Harley support and get bike picked up drop it of to us and we will take a look.Thats going to be tomorrow ! Is it going to be sumpimg or wot ? I’m worried to say the least. Has any one else had a similar experience ?
Last edited by Puddle63; Sep 30, 2019 at 03:29 PM. Reason: To see if any one else has had a similar experience
Old Sep 30, 2019 | 09:06 PM
Hulkss's Avatar
Hulkss
The manual says to break-in below 3500 rpm for 500 miles. When cruising you should try to be above 2000 rpm and not lug the engine. You do have an engine problem of some kind for sure.
My new engine was run to 6000 rpm at wide open throttle on a dynamometer before I even picked up the bike, so, I never paid attention to any break-in procedure and just rode like I always do. Runs great now and uses very little oil. I do not need to add betweeen 5000 mile changes.
Old Sep 30, 2019 | 09:29 PM
AJ88V's Avatar
AJ88V
Seems like you were running the engine at very low rpm. While it's ok to run low rpm, it's not ok to expect it to pull hard when running there. (not that this is in any way an accusation you did anything wrong!!!)
Early on I noticed how sensitive mine was to the octane of the fuel. 93 octane and all is good. Even 91 octane (considered high test at some stations) will give some pinging at lower rpm under power.
Old Oct 2, 2019 | 02:58 PM
ekb55's Avatar
ekb55
You will find that the "pinging" is very common with the M8. I have a 2017 with the issue. A 2018 M8 with the issue until I added a tuner. I also just purchased a 2018 Low Rider Softail with 500 miles on it, totally stock, it has the slight pinging issue also.
Old Oct 3, 2019 | 12:49 PM
Puddle63's Avatar
Puddle63
6th Gear
Default Reply from Harley
Harley got back to me as they had striped the engine, they recon valve stem guide Bad fitting from factory .so fitting new heads and valves + rings just in case !
Old Oct 3, 2019 | 03:36 PM
AJ88V's Avatar
AJ88V
Wow. Thanks for reporting back to us on this. Genuine engine problems seem to have been pretty rare so far on these Softails. Yours is one of the few I've heard of. Sorry it happened!
Old Oct 3, 2019 | 08:52 PM
Puddle63's Avatar
Puddle63
6th Gear
Default Reply from rare on these softails
Quality control comes to mind ! Harley excuse was tooling not changed frequently enuf (great) As top end engine noise we hear about in these threads, is this the answer !!! NOT GOOD ENUF is it !
Old Oct 3, 2019 | 09:24 PM
Puddle63's Avatar
Puddle63
6th Gear
They tell me the parts they require (heads valves + rings just incase ! They can sauce in two days but a gasket kit is going to take another 21 days or more from the states. That means they will have had my new bike twice as long as me, again not impress to Say the least.
Tool Engineer
Milwaukee Eight (M8)
34
Oct 12, 2019 08:50 AM
eagleeyes17
May 19, 2017 07:53 AM
Dazzauk
EVO
41
Apr 7, 2016 01:56 PM
violentj
Aug 1, 2012 02:51 AM
LS1vazquez
Feb 11, 2006 03:03 PM
