2018+ Softail Models Breakout
Throttle response 114 vs 107
Old Nov 23, 2019 | 04:29 PM
  #41
Hulkss's Avatar
Hulkss
Originally Posted by PA1195
HD uses the same cam for the 107 and 114 - 25400190 - from what I can determine. Different air filters for the 107 vs 114 but likely the same exhaust by model. Seems to me that the 114 should have a different cam and tune to match the bore and stroke/displacement and I suspect the Stage II takes care of that according to HD's charts. A look at the factory maps for each engine would be interesting.
I've had a 107 Deluxe, a 114 Heritage, and now 114 Fat Bob. The Deluxe was smoother through the rpm range than either 114's, but the Fat Bob is smoother than the Heritage ever was especially as rpms go over 3000. From idle up the 114's pull well with no flat spots so far and the torque can be felt over the 107 especially if the throttle was left pretty much alone and the clutch just engaged as a test.
Last I checked the 107 and 114 use the same two balancers in the Softail line so maybe they're tuned for the 107 more than the 114's.
Both motors use the same connecting rods. The wrist pin is located higher in the 114 piston to keep the same deck height. The 107 and 114 pistons weigh the same. All the stage kits keep the piston weight the same so the engines stay balanced. The cams are the same in both engines. Any difference in "smoothness" is mainly due to the difference in seats, handlebars, exhaust, suspension, and foot rests.
Old Nov 23, 2019 | 04:43 PM
  #42
CoolBreeze3646's Avatar
CoolBreeze3646
Technical Stuff for those so inclined:
Milwaukee-Eight™ 107
Bore 3.937 in.
Stroke 4.375 in.
Displacement 107 cu in
Compression Ratio 10.0:1
Engine Torque 111.4 ft-lb
Engine Torque (rpm) 3,250
Milwaukee-Eight™ 114
Bore 4 in.
Stroke 4.5 in.
Displacement 114 cu in
Compression Ratio 10.5:1
Engine Torque 124 ft-lb
Old Nov 23, 2019 | 07:58 PM
  #43
PA1195's Avatar
PA1195
Good discussion and thanks for all the info. When it warms up in late April we can ride again.
Old Jan 29, 2020 | 06:15 AM
  #44
user 7298720's Avatar
user 7298720
I meant to update the this thread, better late than ever!
I got the SE Tuner, and after loading Stage 1 tune and doing one full autotune session, the problem is completely solved. There is a night-and-day difference, for me anyway, in throttle progressivity off-idle, especially when cold. It is now exactly how I remember it from my 107. Just FYI for others that might have noticed the same thing.
Old Jan 29, 2020 | 09:17 AM
  #45
tmac00333's Avatar
tmac00333
I have a slight hesitation in my 114 shifting from fifth into sixth. All other gears are smooth as silk and powerful as a raging bull.
sgl0226
Oct 28, 2020 04:45 AM
ReneeG
May 14, 2016 06:52 AM
Texas_Grim
Feb 18, 2015 04:52 PM
03psd
Jun 17, 2012 06:24 PM
engineer
Feb 29, 2008 07:56 PM
