2018+ Softail Models Breakout
Few things I need help with
Old Jul 18, 2020 | 08:51 AM
Burbur2's Avatar
Burbur2
Default Few things I need help with
Hi guys
i would appreciate some help on few small issues I am dealing with on my 2019 Heritage.
1. I notice what I believe to be belt noise when deceleration around 30 mph. I aligned the wheels before and I can twist the belt about 45degree at measuring point which make me believe tension is not too tight. Still annoying noise. When I cruise and pull clutch while slowing down all is nice and quiet just at certain speed in gear I hear it.
2. Any ideas what might cause some rattling sound in my front end around triple tree cover while hitting bumps on this model?
3. Have a bit of a weird noise when slowing down when front end dive kinda like squeak of some kind. Nothing major but I can hear it.
4. While installing riser I accidentally dented the tank (about dime size) on the opposite side of the clamp from brake line on triple tree cover. No paint damage just small indentation. Wonder if this can be repaired as paintless dent repair?
5. Speedo fogging I ave seen post to drill tiny hole in the back that should fix it did anyone tried it?
Thats all “issues” I got with this bike that I try to investigate. Any tips would be appreciated
Old Jul 18, 2020 | 09:18 AM
jimsreddyna's Avatar
jimsreddyna
1.) Buy the belt tensioning tool and adjust the belt per the service manual.
Old Jul 18, 2020 | 10:48 AM
Slyvest's Avatar
Slyvest
2. I know on my lowrider the gas cap rattles. Check that out it may be what you are hearing.
Old Jul 18, 2020 | 09:14 PM
bambambam's Avatar
bambambam
I had the noise on deaccleration at the same speed that you have.Took it in and they said that I had a sticker on the belt,removed and adjusted belt.Noise was gone until today now I have a noise in all of the gears on deaccleration.I am going to take to my Indy and see if he can figure it out.
Old Jul 18, 2020 | 10:13 PM
Burbur2's Avatar
Burbur2
Please keep me posted wonder what they say
Old Jul 18, 2020 | 11:05 PM
firehouse18's Avatar
firehouse18
#2 steering head bearing needs adjustment. Just had it done for same problem (hard front end rattle hitting bumps).
Old Jul 18, 2020 | 11:35 PM
Burbur2's Avatar
Burbur2
Wonder how to do that.
Old Jul 19, 2020 | 10:07 AM
firehouse18
I don't know but I'm gipoing to research li. I belive it takes a epedial tool.
stevefxdi
May 11, 2013 09:30 PM
sukhoi31
Jun 22, 2012 02:02 PM
brasing
Apr 2, 2009 10:51 AM
forever young
Aug 31, 2008 09:05 PM
94 Heritage
May 15, 2007 09:24 AM
