2018+ Softail Models Breakout
Sport Glide Risers
Old Sep 18, 2021 | 08:31 AM
Bodacious MC's Avatar
Bodacious MC
Default Sport Glide Risers
I've been researching but have not found a definitive answer to my riser question.
2021 Sport Glide FLSB
What is the height of the OEM riser on this model?
What is the max pullback style riser that can be used WITHOUT changing out the brake fluid line or any other cable and wiring harnessing.
Old Sep 18, 2021 | 02:13 PM
pjbuilder's Avatar
pjbuilder
Can't remember the height of the oem riser. I installed the 4" pullback (Part Number: 56269-09 ) with no cable change. Only had to move the clutch cable to the front of the bar. Some say they've used the 6" without changing cables however I would have a tendency to believe 6" would be real tight.
Old Sep 19, 2021 | 08:30 AM
jtodd's Avatar
jtodd
Dimensions were hard to find, but for your research, the part numbers are 55900109 RISER (right) And 55900116 RISER (left).
Old Sep 19, 2021 | 07:21 PM
Bodacious MC
Looking tonight a little closer and it appears that the risers need to 1.25" for the bars?
Old Sep 20, 2021 | 02:16 PM
jtodd's Avatar
jtodd
Yes. 100%, the stock bars have a 1.25" clamping area. That is sometimes different from the listed bar diameter, because some are tapered. But the stock bars are 1.25" diameter, but also with a 1.25' diameter clamping area.
Old Sep 20, 2021 | 03:57 PM
Bodacious MC
Thanks a lot!
Now wondering what the main bottom bolt down thread size is for the stock bars? Guessing aftermarket risers will come with those bolts if they are different than the OEM HD threads?
Old Sep 21, 2021 | 01:30 PM
jtodd's Avatar
jtodd
It is this:
Part Number: 10200616
SCREW 5/16-18 X 1-3/8, socket hd, (Grade 8) (bright zinc)
Old Sep 21, 2021 | 05:42 PM
Bodacious MC
if anyone has a set of 4-5" pullbacks for fat 1-1/4" bars that didn't do the trick for you, I'm interested in buying them.
Old Sep 22, 2021 | 09:10 PM
Bodacious MC
I searched High and Low and seems that all the HD pullbacks are on backorder. Decided to whip up a test set of extensions, to use until they become available. I had some 1.25" stock, cut a pair to 2" each center bored them 1/2" sanded and painted. About 2 hours of messing around but came out pretty well. I flipped the clutch cable in front of the bars and all other wires are fine. In fact another 1/2" - 3/4" of rise should work,( just a guess.?)
Any way went out for a test spin and the 2" rise feels much better on my lower back.
Just shop parts laying around vs $192 for now!
It was nice to retain the Attractive HD top clamp as well.
Old Sep 23, 2021 | 12:17 PM
Sport Glide-Lover's Avatar
Sport Glide-Lover
Stage III
I have the 4.5 inch I can sell you. I brought both the 4.5 and 6 inch to see which one worked better for me.
