Greetings from the foothills of the Adirondacks!. I have a 2021 114 Heritage that fits just fine. I'm very happy with the quality of the ride as well as responsiveness. But there is this repetitious rubbing noise, maybe somewhere from the belt area/ rear end, that is distracting at best and particularly annoying. It isn't too bad when the bike is first used for the day or when things are wet, but it gets louder as a ride progresses. The Harley shop has tried everything they can think of. They ultimately contacted Harley support and were told that this condition occurs with some softails and there is no danger or fix associated with this condition. So the noise continues. I've had quite a few Harleys but have never had this situation or type of response from the factory. I don't want to take my bike to an independent shop, as it is still under warranty. Has anyone on the forum had this noise problem? Thank you.
Thanks Cruiser. It's good to hear there was an easy fix for yours. They loosened mine due to the noise when I first purchased the bike. We'll see if loosening it more can do it.
The noise is NOT normal and I wouldn't accept the answers you have been given from your dealer or HD. I have two suggestions for you.
1. Buy a belt tension measurement tool and check the belt tension yourself. The tool costs less than $10 on Amazon and is easy to use. I have about 15k miles on my 2019 M8 Softail and check my belt tension about once a month after a ride when the belt is still at operating temperature.
2. Not all HD service departments and mechanics are equal! I had a couple of problems on my 2019 that the dealer said were "normal". Took the bike to another dealer that identified the problems and fixed them. Your warranty marries you to an HD service department but not to a specific dealer.
I had a noise similar to yours that ended up being the belt tension as well and that was on my roadglide. It was bugging the **** out of me and I was looking all over the bike trying to find the noise. They are blowing smoke. It's not a softail issue. It is a belt tension issue. My dealer knew what it was immediately. I felt stupid for not checking that in the first place since I do most work on my bikes and I should have checked the tension. Agree with others here, don't except there answer. I bought the belt tension tool after this happened and have checked tension myself on all my future bikes. Not to get off topic but......I have mentioned this in other threads to check torque on your spark plugs if it's a new bike. I found on my last two new bikes the spark plugs were barely tightened. Almost hand tightened. Trust but verify.
Belt tension and or alignment. My 18 Heritage made that noise, I adjusted the belt and aligned the wheel. Adjust it to 5/8 inch at at the tightest spot in the belt and do it with the bike in the upright position with only the weight of itself on the wheel. The loose end of the spec in the manual is 9/16 and it says to adjust it on the side stand, believe me that won't do it. At least it didn't on mine. Adjust it cold.
My vote is the belt tension as well. I found when I rode 2 up that this would happen due to more weight compressing the back and therefore making the belt too tight. I just keep it on the loose side of the adjustment now. Originally I went as far as replacing the rear bearings thinking that they were making the noise after they heated up on a long ride.
