Kickstand
This first photo shows the issue. I'm sitting on the bike with it as close to upright as I can. When I deploy the kick stand it hits the ground around 3" before it is in the fully extended position. If you're not paying attention it will fall over because it is not locked in place.
This photo shows the kick stand fully forward, and you can see the scrape mark it left on my garage floor as I pushed it forward. Not a very good angle in the photo, but you can see how the tip of the foot is pointed into the floor. This is what causes it to dig into whatever surface you are parking on. It won't slide across the pavement like a real Jiffy stand does.
This photo shows it fully deployed and the bike parked and leaning on it. Note how flat the foot is on the floor.
Remove these 2 cap screws with a 5/16 allen socket and it just falls off the bike.
Use a thread chaser to clean the loctite out of the threads or suffer later.
This is all there is to it. You can see where I had previously radiused the edges of the foot in an effort to get it to quit digging into the pavement. It helped, but very little.
I'll be back with more in a little while once the Yaffee part shows up.
This view shows the angle that the kickstand will be mounted at. The mount is laying on the surface that will go up against the frame.
The 2 cap screws circled come with the kit, and the longer one is used in the rear position. Don't forget your blue Loctite, and the torque spec is 40-45 ft lbs.
Mount installed and torqued. You can see that the new fastener location for the stand is down and forward around an inch-ish.
A different view of it mounted showing the new angled mounting surface.
Kickstand mounted.
Much better position of the foot which will allow it to slide over any surface you park on as opposed to digging into the pavement.
The only negative thing I can say about it is that the bike leans over further on the stand which requires more effort to get the bike upright. Not at all a problem for me, but my skinny *** wife is struggling with it, and it's her bike. I keep telling her it's technique not strength, and she said she's not buying that and now she's pissed at me LOL! I have a friend who's a retired Vegas PD motorcycle instructor who will be here in an hour. She listens to him without getting pissed. Ha!
So there you have it, hope it helps. For me personally, it fixed one problem and caused another. She'll just need to learn a new method to get the bike up because I don't want her dumping it because of the shitty kickstand.
Bottom line - highly recommend it on a Heritage, but have no experience with this crappy stand on other Softails.
Might not be an issue for you lot as IIRC you've a lot of concrete but over here most road / car parks are tarmac which can get a wee bit soft
https://www.shoputahharley.com/produ...hoCxuAQAvD_BwE
I'll have a look see at my FXFBS at the weekend as I can't remember ever having to consciously do the tip to the right to fully deploy my stand as shown above, so may not even be an issue for me.
