2018+ Softail Models Breakout
Auto Meter Tach
Old Aug 5, 2023 | 07:14 PM
reynoldss's Avatar
reynoldss
Default Auto Meter Tach
Hey Guys, gals, I would love to mount an Auto meter tach to a 2018 Fat Boy handlebar. Does anybody know if its possible to do this? Back in the day you could just hook one wire to your coil and the other to ground , but I got a feeling this is to good to be true. Help.
Old Aug 10, 2023 | 06:20 PM
reynoldss's Avatar
reynoldss
Nobody??
Old Aug 12, 2023 | 12:45 PM
harkon's Avatar
harkon
To the best of my knowledge it's still the same, however, unlike the old days when Harley had one coil for both cylinders, they now have one coil for each cylinder, so you'll need a tach that can do a single cylinder engine, because you'll only be connecting to one coil. You could connect to both coils and set for a twin, but you would need a couple of diodes to ensure the coils remain electrically isolated.
Old Aug 12, 2023 | 05:29 PM
cwsharp's Avatar
cwsharp
My autometer on my El Camino is digital and I imagine that you have a CANBUS on your 12 or 14 that you have to figure out how to hook up to you ECM. Look up the wiring of the tach and see if it uses a digital signal. Look at a wiring diagram and see if there is a manual coil to tach signal. You are in a bridge area that you may not be able to cross.
Old Aug 13, 2023 | 04:44 AM
Glenn Gorman's Avatar
Glenn Gorman
Ur bike has a TACH built into the Speedometer, in case u didn't know.
Old Aug 14, 2023 | 12:38 PM
Biggzed's Avatar
Biggzed
Autometer makes a line for motorcycle use. I think they call it Pro Cycle. Probably going to be best to give them a call and see what works.
Zach
Old Aug 18, 2023 | 06:41 PM
reynoldss's Avatar
reynoldss
Thanks for the reply guys. I want a tach you can see under acceleration mounted on the handlebars. I can't look down at the digital one from the factory. I built the crap out of a 128 and hell it's all I can do to hold on at W.O.T. . Lol I will give Auto Meter a call.
Sal C
Aug 28, 2020 10:51 PM
Deano1111
Shovelhead
Apr 20, 2015 06:51 AM
bikerlaw
Mar 12, 2013 05:30 PM
lincolnmatthews
EVO
Aug 12, 2012 12:00 AM
DOGKILLR
Jun 22, 2008 04:43 PM
