2018+ Softail Models Breakout
Which cam for sound?
Old Jan 23, 2024 | 01:41 PM
  #81
Since 1968's Avatar
Since 1968
I have a TTS 175 in my 114. It's very similar to the TTS 150 except the timing of the two cylinders is very slightly different in order to make a nice 'lope'. People compliment the sound, and some ask what cam is in it as it sounds really powerful. However, I also have a D&D 2 into 1 as I put more weight on performance than a traditional look, and I never even thought about sound. I personally don't think my bike sounds all that great.
I really think you'll have to find a pairing of cam plus exhaust to get what you're after, probably some sort of dual arrangement. You can hear quite a few combinations on YouTube. Plug in your headphones and have a listen to all the 114's you can find.
Old Jan 23, 2024 | 02:43 PM
  #82
tmac00333's Avatar
tmac00333
Thanks, that's good advice. I'll probably stick with my existing exhaust, which is Tab Performance, ironically that's what I have on the sportster too. I had the S&S on the Heritage before, too quiet for my taste.
Old Jan 23, 2024 | 04:05 PM
  #83
TracerBullet's Avatar
TracerBullet
Call FuelMoto and talk to them
Old Jan 24, 2024 | 11:25 AM
  #84
Old New Rider's Avatar
Old New Rider
Quick related sidebar - why you chose TTS 175 rather than lower for a Heritage?
Old Jan 24, 2024 | 09:43 PM
  #85
Since 1968's Avatar
Since 1968
I planned to install a TTS 100, but had a long phone discussion with the tuner I was going to hire. I had exchanged PM's with Steve Cole and he recommended this tuner, so I felt comfortable that he knew what he was doing with the TTS products. Anyway, he advised that the TTS 100 was perfect for a 107, but would leave some torque and ponies on the table in a 114. So then I said the next bigger cam is the TTS 150, and he said that the 150 and 175 are basically identical, but the 175 has the lobes very slightly offset between cylinder 1 and cylinder 2 to provide a stronger idle lope. I made the immature decision and I suppose my bike isn't quite as smooth as it would be with the 150, but I sure don't notice it and I am very pleased with how it all turned out. Umm, except that my compensator has begun making a bit of noise. I'm just thinking about which way to go with the replacement/upgrade.
Old Jan 25, 2024 | 07:17 AM
  #86
$tonecold's Avatar
$tonecold
I can't help you decide which one, Evolution Industries, Starr Racing, and Cycle Rama are all probably very similar in performance, but I can tell you than Fuelmoto will send it ground free of charge. They carry all three, so any of them will be available if they have them in stock. It looks like the Evolution Industries has a 3 - 5 day lead time before shipping, so that might be a factor.
Old Jan 25, 2024 | 07:39 AM
  #87
heritageblue2013's Avatar
heritageblue2013
Wondering if there is an oil that will give me that potato potato 🥔 sound
Old Jan 25, 2024 | 08:54 AM
  #88
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
See what Utz uses...
Old Jan 25, 2024 | 09:58 AM
  #89
Old New Rider
Thanks for reply. Yeah, I have a 107 and needed a bit more oomph when 2-up riding. TTS 100 did the job.
I didn't want to wait for a 114 order, and a 107 was on the showroom floor so I took it. All good, thanks.
I just replaced my compensator ramp with the cycle rama. Of the varieties out there, it is a high strength alloy 4140, I believe. I think the others are surface hardened but lower core strength. Going off memory, here. I couldn't find it in stock at distributors so bought direct.
Old Jan 25, 2024 | 10:09 AM
  #90
NZLowrider's Avatar
NZLowrider
This is what I've found for the Evolution ramp, I'm not sure what aircraft gear material is but it sound good to me as you wouldn't want it to fail in a aircraft lol
Product Details
Features & Benefits:-
* Specialized heat treated and carburized heavy duty aircraft gear material
* Machined on a 4-axis mill ensures precision quality
* Proprietary heat treating process
* Black oxide coated to prevent corrosion
* Final inspection done via a scanner to ensure tight tolerances
Proudly made in the USA!
* Heavy Duty Ramp from OEM # 40100076 & 40100087
