2024+ Center-Cooled Touring Models 2023.5+ CVO and 2024+ Road Glide/Street Glide/Street Glide Ultra Center-Cooled Gen 2 M8 Touring models
SE Smart Tune Pro Automatic Tuning Module?
Old Jan 23, 2026 | 09:19 AM
SWThomas's Avatar
SWThomas
Question SE Smart Tune Pro Automatic Tuning Module?
https://www.harley-davidson.com/us/e...le/p/41000445A
I'm seriously considering adding this to my bike. I already have the SE Street Tuner and feel like this would be a great addition to get the best touring tune I can. The vast majority of the reviews I've read are positive, with the few negative ones being about price or user error.
Anyone have this installed? What's your opinion on it?
Old Jan 23, 2026 | 09:49 AM
rigidthumper's Avatar
rigidthumper
It doesn't change the allowable range of the SE map (+/- 4% closed loop area, +/- 10% open loop area), but it does allow a much wider area of adjustment.
There are 2 areas in the VE tables: closed loop (<85KPA, <3750 RPM) and open loop (>3750 RPM, >85KPA).
Closed loop uses the stock O2s for feedback. Open loop relies on whatever #s are in the VE tables without active feedback.
If you add the ATM, it will replace the factory O2 sensors with wide band O2s.
Not as fast/accurate in the areas where the factory narrow bands used to work, but able to cover the entire map effectively. Can be used with TTS or PV if you go aftermarket.
Old Jan 23, 2026 | 10:25 AM
mjwebb's Avatar
mjwebb
why bother with VVT? it seems to deliver the smoothest running experience across the entire power band as they have ever developed..personally I wouldn't be throwing money like that at it..look at Steve Cole's recent post and graph of his baseline 117 VVT stock dyno tune below....also, when the SE ATM came out I asked about it here and Steve replied with compelling reasons why a proper dyno tune by an experienced and reputable dyno operator would be a better choice..I took his advice because our home dealership had / has that level of expertise and was glad I did..my 107 ran fantastic from our coast to over our Cascade mountain range....maybe he'll come along and elaborate further
https://www.hdforums.com/forum/2024-...in-2026-a.html
Old Jan 23, 2026 | 10:41 AM
SWThomas's Avatar
SWThomas
So you're saying the wideband would be better? I'm mainly trying to ensure I get the proper amount of fuel across all ranges.
Old Jan 23, 2026 | 10:43 AM
SWThomas's Avatar
SWThomas
My local dealer doesn't have a dyno. I guess I could look into other dealers in the state. But it'll be a crapshoot on whether the guy doing the tuning has any expertise.
Old Jan 23, 2026 | 10:53 AM
mjwebb's Avatar
mjwebb
yeah, I certainly wouldn't trust the job to just anyone..so the question is, what isn't your 121 VVT doing that you wish it would be better at? not just the expense, but adding some complexity and having it attached to the bike etc..I just don't recall anyone owning these engines ever complaining about how they run, maybe don't fix what ain't broken is wise in this case? just evaluating pros and cons &, risk / reward .. have you done a Custom Ride Mode yet?
Old Jan 23, 2026 | 10:58 AM
SWThomas's Avatar
SWThomas
The only thing I don't like is the lugging at low speed. I did a stage 1 with TAB Mufflers and an HD breather, loaded a Stage 1 tune with the SE Street Tuner. I haven't done a Smart Tune yet but am planning on it. I'm just trying to get it as smooth as I can.
Old Jan 23, 2026 | 11:07 AM
mjwebb's Avatar
mjwebb
I was talking about creating a Custom Ride Mode..where you can select different settings from Road, Rain, Track, Sport Mode, throttle sensitivity, engine braking, etc. ( The procedure is in your OM) I created one that I love and use 95% of the time, only ever using Rain Mode when conditions are 'greasy'. Highly recommend playing around with this and dialing that in before moving on to $ 'solutions' .. you may just be surprised at how satisfying it is, I was anyway
Old Jan 23, 2026 | 11:16 AM
SWThomas's Avatar
SWThomas
I'll look into that. Thanks! I definitely don't want to spend money if I don't have to.
Old Jan 24, 2026 | 03:15 AM
Slingshot383's Avatar
Slingshot383
The cure for lugging the engine is to drop a gear. Lugging is hard on the engine and hard on the compensator.
