Bluetooth adapter
Old Jan 14, 2015 | 04:31 PM
Iron Cross Audio's Avatar
Iron Cross Audio
Former Sponsor
Originally Posted by jussdandy
Has anyone on here try to Bluetooth adapter?
Would like to play music from my iPhone but don't want to change the head unit!
Saw them on line where they just plug into the 3.5 mm Jack.
They are cheap enough just don't know if it work.
Thank you
Randy
We have a completely internal mod for Bluetooth reception.
No external cables, nothing to charge, track advance and restart using the right arrow button on the radio faceplate, auto connect when you start the bike.
http://www.ironcrossaudio.com/bluetoothmod.html
Old Jan 14, 2015 | 06:03 PM
jussdandy's Avatar
jussdandy
Thanks for all the great ideas
Definitely going to pick one of those
As far as iron Cross option my bike is to old, 2003
I don't mind changing the head unit I just don't want to mess with the handlebar controls
Old Mar 31, 2015 | 12:19 PM
smokewrench's Avatar
smokewrench
Stage II
Default mpow good stuff
made this up !!! good stuff with help from mpow
Old Apr 1, 2015 | 04:22 AM
Dguy's Avatar
Dguy
Originally Posted by smokewrench
made this up !!! good stuff with help from mpow HARLEY AUDIO COOL UPGRADE - YouTube
That's a cool setup but just so you know, you are likely going to break the AUX port with the weight of the unit hanging on the end. I know it doesn't seem like much but it has happened often and those AUX ports are flimsy to begin with. You need a 90 elbow and then use some velcro to "stick it" to take the weight off the port.
Ask Iron Cross how many AUX ports they've fixed.
Old Apr 1, 2015 | 08:30 AM
smokewrench
Stage II
Default ok
it came with a cable too , I might run it inside the fairing , thanks for the info
Old Apr 5, 2015 | 12:52 PM
Marty33's Avatar
Marty33
I use a Bagger Nation Bluetooth that plugs into the cig lighter. Has worked great so far.
ZEROPILOT
Audio Systems
Jun 4, 2019 06:34 PM
ambrose
Audio Systems
Jul 25, 2017 04:15 PM
vistavette
Mar 11, 2014 10:29 PM
killerrgu
Audio Systems
Jun 9, 2012 09:26 PM
Thirdup
Nov 25, 2007 01:36 PM
