CB Antenna question
Old Feb 24, 2015 | 06:49 PM
pp6000v2's Avatar
pp6000v2
Default CB Antenna question
I'm adding the CB module to my HK unit.
Looking through the parts diagrams, it looks like bikes up through '08 used a load coil and tunable antenna, and '09+ use a pre-tuned antenna and omit the separate coil.
The parts I would need price out to be nearly the same going either way. Does anyone have an opinion on which antenna system works better? I have a shelf in my TP that would cover the load coil, so space isn't a consideration.
Old Feb 24, 2015 | 10:28 PM
Ride my Seesaw's Avatar
Ride my Seesaw
I would go with the tunable antenna. That way you can actually resonate the antenna to maximize your transmitted power into the air. I'd do this rather than have it turn into heat through some inbuilt capacitive/reactance gimmick that a 'pretuned' antenna will come with. Newer is not necessarily better.
DeneFXDWG
Audio Systems
Sep 3, 2015 07:20 AM
Charlie Fogg
Feb 25, 2015 07:29 PM
Texas Rider 3
Audio Systems
Mar 22, 2013 08:06 AM
marvo75
Mar 3, 2012 04:31 PM
Casper
May 11, 2008 04:21 PM
