Suggestions
Old Apr 28, 2015 | 08:12 PM
Travis Whittaker's Avatar
Travis Whittaker
Originally Posted by haze324
If you don't mind risking loss of FM reception you could get an RZ42000D amp for 100 bucks.
You have a nice bike, with great speakers. I don't think the PBR4 has enough behind it to really push those speakers. The RZ has hi level inputs too.
Good luck!
LOL these speakers are only rated for 100 watts and 125 watts per, I don't think running that kind of amperage would be good for them. Should pot something back this weekend oh and thanks for the compliment I have been working on it for a couple of years now. Still no motor work yet, but then again if I did that what would I do next year.
Old Apr 28, 2015 | 08:35 PM
haze324's Avatar
haze324
What speakers are we talking about. For the BT 7.1's I've used a PPI 900.4 pushing 150w, and now a 4180 sending 160-180w.
They can take it man.
I
Old Apr 28, 2015 | 09:22 PM
Travis Whittaker
ok so I just ordered my line level converter and after a lot of thought and research I chose the higher end model I went with the Rockford Fosgate T400x4AD. I think in the long run it will be a better choice. So with this amp I shouldn't need a real line level converter since it has an adjustable input, correct? I am just trying to get my ducks in a row and if I need to buy something prior to amp arrival then I want to do so. Like I said currently the PBR400X4 is hooked up and running so plan is to just swap the amps using all the PBR setup which was all factory Rockford. LMK your thoughts.
Thanks
Old Apr 28, 2015 | 09:32 PM
Travis Whittaker
The BT 7.1 speakers are rated for 125W continuous 240W peak. The Infinity Kappa Perfect 6.1 Component set are rated at 100 continuous 400 max per side. I am not one to over power my speakers as I would rather drive tem at max amp a tad bit under speaker cont. just my .02 though.
Old Apr 29, 2015 | 12:16 AM
SBates08's Avatar
SBates08
Power isn't what you should be worried about. Power won't kill a speaker. It's the under powered speaker that distorts that causes them to blow. Ideally you want an amp with a good amount of head room so that your not overworking the amp to drive the speakers to their peak abilities.
2010 Limited with some stuff
Old Apr 29, 2015 | 07:01 AM
Gannicus's Avatar
Gannicus
Yeah That!
Old May 11, 2015 | 08:29 PM
Travis Whittaker
Received new amp and installed it adding in a line level converter and low level rca inputs. With this new amp install the sound is now great however my speakers are now randomly cutting out, they do not cutout at the same time they do it sporadic with no rhyme or reason. I have yet to have both speakers drop at the same time, any thoughts?
Old May 11, 2015 | 08:46 PM
haze324's Avatar
haze324
You need to lower your gains, the amp is going in and out of protection mode. I know the amp comes with clip light indicators but you can still be overdriving the signal. What do you have your gains at? The 12 o'clock position is the happy spot.
Old May 11, 2015 | 09:35 PM
Travis Whittaker
Think I am closer to 3/4, really disappointed in the HK head unit. these head units seem to be very poorly made. I will try to turn down gains and see what it pushes but if I remember right volume was low at mid gain level. Maybe next step is a new head unit. Guess we will just have to wait and see, more to come.
USMC0352
Audio Systems
14
Mar 17, 2018 07:02 PM
bc73
Audio Systems
Apr 27, 2017 06:16 PM
capnkirk
J&M Motorcycle Audio
Oct 13, 2016 10:36 AM
matt76cmich
Audio Systems
Aug 23, 2015 06:49 AM
Turbo Flux
Audio Systems
May 1, 2012 06:32 AM
