cerwin vega B2
Old Aug 16, 2015 | 10:04 AM
Scooby1426's Avatar
Scooby1426
Default cerwin vega B2
I was wondering if anyone has this amp what do you have it set at? Crossover hp, lp, or flat? Not sure what these all mean. Read the manual but still confused. Running this amp with stock hu, kappa 62.11 speakers only.
Old Aug 16, 2015 | 10:12 AM
haze324's Avatar
haze324
You crossover essentially is what freqs you want to cut off from the signal. So your very low freqs (bass) probably can't be reproduced by a 6.5 speaker. At low volumes the flat or passing all freqs will sound better, but at volume those low freqs may cause distortion...especially from the stock HU. If set an HPF around 50-60hz cut off. You'll get more volume this way.
Old Aug 16, 2015 | 10:13 AM
csg04rkc's Avatar
csg04rkc
Crossover hp
Around 90-110 on hertz
Scooby1426
Audio Systems
34
Oct 23, 2017 05:47 PM
timdhawk
Audio Systems
Sep 10, 2017 10:38 PM
ReallyInSturgis
Audio Systems
Aug 21, 2017 10:43 PM
Mixter
Apr 2, 2012 05:14 PM
kyleplusitunes
Jan 13, 2012 03:39 PM
