It's the 300w 4 ch setup. I'll do some looking on the kappas. Don't listen to a bunch of fm- mostly xm from the stock HU. The kappas mount ok without modification?
Can't run the Kappa's with the 4 channel PBR. Gonna have to change amps. On a budget get the power Acoustik RZ4.2000D. You will also need 6.5 adapter rings for the Infinity's.
