Most likely vibration damage to the main board of the radio.
On the 07, probably caused by riser bolt contact or broken fairing brackets
OK Thanks you didn't know this but I changed out Radio original would blow fuses when turned On I heard this Radio play so I knew it was good
So do you think it could be a Switch Problem? ? THANKS Tom
