Tailwind, may be I'm overthinking this, but in the way you have it setup I'm concern with the heat trapped inside those foams and eventually damaging the driver.
I'm going to play with some configurations of the Rings and see what works best for me.
Like I said, just don't use them if u have a concern. And if these foam rings scare u, u better get the polyfill u have been using out in the non flammable metal dumpster ASAP.
I would not carry anything flammable in your saddlebags either!!!!!!
Can I get 2 of those NVX'S in there with a 4180 without buying the amp tray? If running 2015 flhxs, 6.5 radio, 7.1's pros with Biketronics brackets.
Thanks
Thanks
Have not tried it so not gonna guess and send u down the wrong path.. Sorry!!
Worst case scenario is that u try it and have to buy a JM amp tray.
Thanks
T - How bad did those two NVX's mess with your FM reception?
