Adjusting gains without load
Old Jun 30, 2017 | 06:52 AM
flcusat's Avatar
flcusat
Default Adjusting gains without load
OK guys, when we adjust the gains we usually disconnect the speakers, and using a 1 KHZ tone at whatever level (0db, -2.5db, -5db, etc) read the voltasge at the output of the amp with a voltmeter or use an oscilloscope.
The question is, does the amplifier behave the same way once with connect the load (speakers)?
In anothe words, if we adjust the amp to let's say 100 watts without load, does the power remain the same once we connect the speakers, or it is less? Assuming we were measuring at the same 1 KHz and level used for the gain adjustment.
Old Jun 30, 2017 | 09:06 AM
Tailwind's Avatar
Tailwind
Are u building a lunar lander or something?
Use the DMM without a load and put a pencil mark on the amp as the max gain position for the speakers in play. RMS x 150-175% (never exceeding max/peak/program) Then throw all that shix away and set the gains by ear, not to exceed the pencil mark.
Luv,
Caveman
Old Jun 30, 2017 | 09:40 AM
BaggerBill103's Avatar
BaggerBill103
Luv,
Caveman
^^^Exactly what I do^^^
Luv,
Fred Flintstone
Old Jun 30, 2017 | 09:43 AM
Gannicus's Avatar
Gannicus
The amplifier is static. If it's rated 150 watts RMS @ 4 ohms. That spec never changes but it does fluctuate as we play our music. When you are setting the gain all you're doing is matching the input signal to the HU or in technical terms it's known as the preamp stage. All it does is control the shape of the sound. The rated amp power provides the strength of your sound. So basically two stages. Preamp and Master volume. In other words all the gain settings do is determine how clean or how dirty your sound is. So to answer your question YES the power remains the same regardless. Like I always say when you guys get deep in the weeds with these technical discussions. Your ears are the best gain setting tool out there. I'm sure you'll get many more thoughts on the subject like we always do when these discussions start. But those are my thoughts on the subject.
Old Jun 30, 2017 | 10:07 AM
Makdaddy's Avatar
Makdaddy
If you look at Slyes sheet on power Its scaled
So output @2 ohms is XX for Voltage will be higher then the Voltage on 4 Ohms
So it is load dependent
But the answer to your question is yes Sort of
Old Jun 30, 2017 | 10:24 AM
SBates08's Avatar
SBates08
I feel it's up to the user to know what he's setting the VAC for. Either by using the supplied chart or by doing the math. As Gann stated the amp is the constant. The load will determine the output. I think using the DMM gets a lot of folks in trouble because they don't fully understand the concept. I very seldom ever use one but when I do I never leave the gains set there and just run it. Like T I mark the spot and retune by ear knowing past that mark is no mans land.
Luv,
Hoss C.
Old Jun 30, 2017 | 10:36 AM
Makdaddy's Avatar
Makdaddy
Luv,
Hoss C.
Agreed
Thats why its important to know the Volume level of all you sources and your Music
Old Jun 30, 2017 | 10:55 AM
BaggerBill103
Luv,
Hoss C.
T doesn't just leave it there. That is the maximum setting on the gain. Then he fine tunes by ear. Never to exceed this point marked during setup.
Old Jun 30, 2017 | 11:06 AM
BaggerBill103
Luv,
Hoss C.
Agreed
Absolutely!! I set my installs to my customers source music. I start with my iPod at full volume, because I have never used any other device that gives me a louder music source. Then I use all of his devices and give him his max volume for each of these devices.
Old Jun 30, 2017 | 11:10 AM
SBates08's Avatar
SBates08
Yessir that's correct.
