Head unit upgrade help
Old Dec 12, 2017 | 08:33 AM
Weeboy1's Avatar
Weeboy1
Default Head unit upgrade help
Hi all,
Want to upgrade from the stock HK. In 2010 ultra
Budget $500ish
Presently running a PN350 and kappas. Don't plan to go beyond the fairing speakers.
Sounds good city. Not the best at 75.
Want better SQ , usb and bluetooth capabilities and I guess a cd.
Presently listen to mostly iPod via aux. and occasional cd.
Considering Sony Mex m100 or 71 . Would there be a benefit of the better amp of the 100? That's seems to be the difference in the 2.
Can I make due with the PN amp? Or should I upgrade.
Would also get a Bt1005 retro kit.
Best place to purchase needed gear?
Other thought was for my purposes for $299 going with the aquatic .one purchase Pull old head out and install aquatic .
Thoughts?
Thanks
Old Dec 12, 2017 | 08:36 AM
Mike@FoxRiverCycle's Avatar
Mike@FoxRiverCycle
Former Sponsor
i have installed alot of the aquatics.very nice budget plug and play unit
Old Dec 12, 2017 | 08:51 AM
BaggerAudioLab's Avatar
BaggerAudioLab
I'd get the Sony MEX 71, when you use an amplifier you by pass the radios amp so no need for the extra power from the radio. The Scosche hand control kit is a bit cheaper then I'd bump up amps to a Cerwin B52 on you budget.
Old Dec 12, 2017 | 09:03 AM
truejdm's Avatar
truejdm
This is what I just put on my bike a week ago. The Scoche is very easy to wire up. Can see the screen of the sony in any light.
Old Dec 12, 2017 | 09:04 AM
Weeboy1's Avatar
Weeboy1
Thanks Mike and Alex for the quick reply.
Aquatic may be out anyway I don't think that model plays off a usb it just charges a usb device.
Alex is the scosche kit as dependable as the bt. Found the bt for 199. For everything I need.
What's the part no. For the needed scosche kit?
Thank you again
Old Dec 12, 2017 | 09:10 AM
truejdm's Avatar
truejdm
For my 2011 SG I used model HDSWC1. Should be the same for yours.
Old Dec 12, 2017 | 09:38 AM
Weeboy1's Avatar
Weeboy1
Thanks brother.
Also found part# for mounting kit about $60 can.
Do you happen to know if the bt splash cover fits the scosche radio frame?
I prefer it to the scosche.
Old Dec 12, 2017 | 09:46 AM
truejdm's Avatar
truejdm
That I do not know. The Sony is a marine radio, so I didn't opt for the cover.
Old Dec 12, 2017 | 10:18 AM
SBates08's Avatar
SBates08
Just because it's Marine rated doesn't mean it's waterproof. If you ride in the rain I'd advise getting a cover for it.
Old Dec 12, 2017 | 10:28 AM
truejdm's Avatar
truejdm
Good point.
