Street Glide Special - New system thoughts?
Old May 27, 2018 | 04:53 PM
Badbagger's Avatar
Badbagger
Default Street Glide Special - New system thoughts?
Going to be picking up a 2019 Street Glide Special. Been outta the audio side of things for a good while. Years ago I ran a Hawg Wired amp and speakers. None the less the goal is to have a system that’ll provide clean crisp sounds at speeds of say 75 mph. I previously used my iPod with a ton of music on it and still have that but will be adding to it unless there are better options. The HU can disappear if need be and I’d have two fairing speakers and possibly tweeters. Amp is a for sure. Budget is $750 to $1,000 give or take. I’ve learned a long time ago, do it once and do it right. Having said that, any system suggestions from the gurus? I’ll install myself and no plans for speakers in the bag lids.
Thanks
Old May 27, 2018 | 06:00 PM
USAproud's Avatar
USAproud
Solid setup for that budget is the JL audio MX500/4 or XD400/4, BT linelevelers, DD audio AW6.5 and AT28 tweeters. Probably one of the best 2 speaker setups out there and still use your factory headunit
Old May 27, 2018 | 07:37 PM
jory434's Avatar
jory434
Or..
J
BT355 line levelers
PRV Neo 4 ohm 6.5 speakers
DD B3 Horns
JL AUDIO 280/4 amp (bridged) or a Cerwin Vega B52 amp.
Not hating on any other suggestions, but I’ve installed this system and it works real good too.
Old May 27, 2018 | 08:17 PM
Badbagger's Avatar
Badbagger
Much appreciated, putting a “to do” list together.
Old May 27, 2018 | 08:32 PM
InthewindMN's Avatar
InthewindMN
Originally Posted by jory434
Or..
J
BT355 line levelers
DD B3 Horns
I’ve heard others say the pa speaks don’t have a full sound with good lows. I would love to hear a video of this system.
Old May 27, 2018 | 08:34 PM
USAproud's Avatar
USAproud
Or..
J
BT355 line levelers
DD B3 Horns
Which prv? Do you have a model number?
Old May 28, 2018 | 06:46 AM
Badbagger's Avatar
Badbagger
If anyone has any video f the suggested systems that’d be a big plus.
Old May 28, 2018 | 09:17 AM
jory434's Avatar
jory434
https://www.parts-express.com/prv-au...-ohm--294-2706
That is the speaker in my bike. They require some fab work to put in the bike, depending on which bike you ride.
Old May 28, 2018 | 09:21 AM
USAproud's Avatar
USAproud
Very good speaker indeed
Old May 30, 2018 | 12:12 AM
azmaniac's Avatar
azmaniac
https://youtu.be/qmV8SVrHoLo
