ARC Audio
Old Jul 10, 2018 | 03:28 PM
  #31
Hoyt 1911A1's Avatar
Hoyt 1911A1
In my understanding resistors just create a voltage drop, to change the frequency you would need capacitors as well.
Old Jul 10, 2018 | 03:46 PM
  #32
InthewindMN's Avatar
InthewindMN
Originally Posted by Dsm Limited
I understand the resistors take care of the radio seeing a load, but do they flatten out the Boom Eq curve as well? Is that eq curve not as drastic as we once believed ?
Is that why arc says a LL is not required m
From the way Arc explained to me the resistors are only there to keep the radio going. They didn’t flatten the curve. That needs to be done with the psm.
Old Jul 10, 2018 | 04:11 PM
  #33
Dsm Limited's Avatar
Dsm Limited
I guess i don't understand why arc says a liner leveler is not required, even if they don't sell you a psm
Old Jul 10, 2018 | 04:17 PM
  #34
SBates08's Avatar
SBates08
IMO, and that's all it is is my opinion, but if your not using a PSM or some sort of DSP on the Rushmore, you should be using the BT355.
Old Jul 10, 2018 | 05:19 PM
  #35
Adenton528's Avatar
Adenton528
Agreed.
I think the confusion in this thread is that OP had dsp and another did not.
So as bates said, without a dsp on a Rushmore you'll need a BT355.
If you have a the arc dsp, the arc harness is recommended.
Old Jul 10, 2018 | 05:30 PM
  #36
Dsm Limited
Thanks andy...... now that makes sense!!!
Old Jul 10, 2018 | 05:53 PM
  #37
arlington's Avatar
arlington
Call Arc Audio ask for Brad or Grimele., they'll answer all your questions for you. They open 8:00 Pacific time.
Old Jul 10, 2018 | 09:23 PM
  #38
marcodarq's Avatar
marcodarq
for the op
install the high level in with the ARC/harness or resistors as they describe in their tech document, set amp crossover switches to full range, turn amp gains all the way down!! can't stress this enough to start with gains down. install the psm software on your laptop or pc, download or reload the stock ARC tune. wire up your speakers left and right on channels one and 2. do not bridge the amp.
once that is done, turn on the system plug your laptop in and open the arc software. confirm the crossover settings, starting at hi pass @90hz with the lw or butterworth and a 12 or 24 slope. start playing a song with lots of musical range and energy, turn the head unit up to about 60% volume. begin to slowing turn up the amp gains to about 30% from 0. how does it sound?.
at this point you begin to go to the EQ menu and the main gain in the arc program. experiment with the eq settings till you find something that you like, keeping an ear out for distortion or anything that makes the speaker sound weird in any way. make sure that you link the eq setting left to right in the software. dont forget to start with a lower gain setting in the software also. you also have to do this with the bike running. once you get it sounding pretty good, begin to raise the master gain in the software, constantly keeping an ear out for distortion or abnormal speaker sounds/ behavior. every time you bump the gain up, listen, tweak, repeat till you think you like it. then name and save the tune to your computer, then save it to the preset channel of your choice.
repeat the process till you are happy with the results.
there are lots of videos on youtube about the PS8, watch them, the PSM is very similar and after watching the videos and working with the software you'll get the hang of it and be able to adjust it to YOUR liking, which to me is the most important part. the only other thing that i might recomend is to have a hi powered fan running on the engine to help keep it cool while you are working with it, when i put these on a rushmore bike, i plug the usb cable into the psm,(sometimes a dab of clear silicone to keep the connection good and secure, not in the cable, but on the outside of the cable case and the psm case) and route the cable either through the glovebox, or through the forks so that i can gain access to it, so that i can re-tune without having to take the fairing off and on again, just plug it in , play and re-store the cable and go.
post up your results.
m
Old Jul 11, 2018 | 08:02 AM
  #39
cshocker's Avatar
cshocker
So I called Arc yesterday and dude told me to use the Biketronics LL or their HD harness for a 2014 Street Glide with Arc Moto 600.4 amp and PSM. He said the LL will do same function with resistance issue as the harness and that the factory Highlevel harness on the PSM has resistors on it. Now I'm even more confused, lol.
Old Jul 11, 2018 | 08:16 AM
  #40
Tailwind's Avatar
Tailwind
I clipped the BT355 wires and fixed it in the big green can and used the harness to go right into the ARC PSM speaker wire input. Never had a an issue w resistance.
Or u can use these biatches plugged into the speaker output harness and wire it to the PSM input harness.
https://vtwinaudio.com/product/vtfsp...y-ft-spk-wire/
T
kryingame
Audio Systems
19
Sep 11, 2015 08:18 AM
Terminator69
Audio Systems
Apr 6, 2015 02:24 AM
goose136
Audio Systems
Jul 15, 2014 11:18 AM
Da Shadow
Audio Systems
Oct 20, 2013 09:37 AM
av ultra
Mar 10, 2013 01:19 AM
