Pre-rushmore ultra, looking for minimum 4v pre-amp output, eq with hpf and slope control, and REAR USB. Marine grade woud def be a plus.
How bout some suggestions?
Y'all know I don't know anything about head units but the signal voltage adjustment of the Arc PSM was just what the doctor ordered for my mismatched amps. I can feed that greedy RF TM400x4ad with what it wants without overpowering the front amp.
Yoop with a PSM in the picture if may allow you to pick your head unit based on the gee whiz functions instead of narrowing the search based off of voltage and EQ functions.
Kenwood 702 or 998 excelon. with the metra install kit weather is not an issue. I currently run the 702, but wanna try the 998, it will be here soon.
m
It took me a second to realize there was only one character different in the model number. They look the same and even seem to cost the same but that tuning app might be a futureproof feature.
