Amp Decision
Old Mar 9, 2019 | 02:49 PM
Delgado130's Avatar
Delgado130
Default Amp Decision
I have a Soundtream pn4.1000d powering Vo 6x9`s on front channels and two Prv mb600ft`s bridged on rear channels. I want to replace this amp with a Soundigital 800.4 or 1200.4. Do I really need the 1200.4 putting 788 watts rms into these 8`s? I`m thinking 522 watts rms will be more than enough. The sensitivity of 8`s are 96 db.
Old Mar 9, 2019 | 03:32 PM
marcodarq's Avatar
marcodarq
what is the ohm rating on the PRV? if they are 8 ohm like I rememeber, you have to remember that if you are going to bridge the amp and wiring the speakers in parallel to get that 522 watts, you still have to divide that by 2 also because you have the 2 speakers in play, that would let each speaker see 261 watts. it is my opinion that they need more than that, so i would use the 1200.4 if you have the room to install it.
m
Old Mar 9, 2019 | 03:43 PM
Babyboy's Avatar
Babyboy
The PRV 8mb600ft are an 8 ohm speaker which will take the power of the 1200.4 in bridged mode all day long. Then the VO6x9 wired in stereo you would have to dial back to keep them from self destructing.
The 800.4 would work but you would have little to no headroom.
My suggestion if you have the room would be to go with the 1200.4 4ohm version
Old Mar 9, 2019 | 04:02 PM
Delgado130's Avatar
Delgado130
They are rated for 300 rms a piece
Old Mar 9, 2019 | 08:52 PM
Babyboy's Avatar
Babyboy
300 rms @8 ohm
Old Mar 10, 2019 | 06:15 AM
marshallb's Avatar
marshallb
Are rings readily available for the PRV forte 8s Babyboy?
Old Mar 11, 2019 | 12:47 PM
cfave's Avatar
cfave
Babyboy, if you dont mind, would you explain this line? what is the differences in wiring up a pair of speakers. I understand Stereo and Mono but, how would they be wired?
Thanks
Old Mar 11, 2019 | 01:09 PM
Babyboy's Avatar
Babyboy
Thanks
The 1200.4 4 ohm amp would be wired to the 6x9 In stereo and bridge 2 channels to the 8s wired in parallel to create a 4 ohm load.
The 1200.4 amp will put out more than the advertised specs. Also as the DC input voltage raises so does the output of these amps.
Old Mar 11, 2019 | 03:12 PM
ssmorga78's Avatar
ssmorga78
I know that Bagger Audio Labs did make rings just for those PRV Forte 8's. I would say hit up Haze, but he's not selling anymore .... just installing/tuning. So if you can find Henry, give him a yell and see if they still make them.
Old Mar 11, 2019 | 07:30 PM
soonerglide's Avatar
soonerglide
Had a friend make these on his cnc router. Not perfect but close enough for me. Just had to do some grinding to fit the bag.
