lowers?
Old Apr 1, 2019 | 08:53 PM
1968gts's Avatar
1968gts
Default lowers?
I need help! looking for suggestions on what lowers to run... my set up is 6.5 infotainment with DSR1 ,Soundigital 800.4 evo ,wdxmoto6 G-2 in the fairing.... looking for ideas as to what would compliment my system in the lowers?
Old Apr 1, 2019 | 09:19 PM
marcodarq's Avatar
marcodarq
the Mmats Pa 601.4's or the yellow basket Ground Zero's, or the Hertz SV 6.5, and the DD VO6.5 should all go in that placement easy enough, just depends on your budget.
.m
Old Apr 1, 2019 | 09:52 PM
Gannicus's Avatar
Gannicus
PRV's All day everyday.
Old Apr 2, 2019 | 12:04 AM
Tailwind's Avatar
Tailwind
Oh shix!!! Team PRV is back in the house!!!! Lol!!!
I miss ya brother!!!
T
Old Apr 2, 2019 | 08:47 AM
FrenchieM's Avatar
FrenchieM
What he said ^^^
Old Apr 2, 2019 | 08:56 AM
SBates08's Avatar
SBates08
Originally Posted by FrenchieM
What he said ^^^
What they said!!!!!!
Old Apr 2, 2019 | 08:58 AM
travelingypsye's Avatar
travelingypsye
Prv's will do the trick but need to grind off the corners to make them fit. I opted to put a set of hertz sv's in my lowers and they dropped right in.
Old Apr 2, 2019 | 10:54 AM
marcodarq's Avatar
marcodarq
I will have to agree, as I'm team PRV also, i just listed what i did cause they dont need the grinding work, if your willing to do the metalwork i'd definitely say PRV 6MR500 all day, 4ohm.
m
Old Apr 2, 2019 | 10:59 AM
Juice's Avatar
Juice
m
There is debate that the 8 ohm play lower? I know the specs are the same! But, they do cross lower and sound warmer.
Juice
Old Apr 2, 2019 | 11:19 AM
InthewindMN's Avatar
InthewindMN
It’s easy to jump on the PRV bandwagon since it’s a good speaker but I think it really depends on the rest of the system, goals and budget. They work well but I think there are others just as good or better depending on your needs.
