Tuning Basics 101
Old Nov 3, 2019 | 09:31 AM
sbeamer's Avatar
sbeamer
Question Not Certain
Originally Posted by Adenton528
Honestly it's probably a speaker spec issue. For your case, I'd HP the fairing and lowers at 115-125 and let those margarita bowls in the lids make up for the rest.
I was looking all over and this might be the closest place to get an answer. I have a stock 6.5 Boom hu. With a Mmats 4110 amp. There is a gain dial, I can do that. Then there is a frequency dial. I have LP, Full Pass, and LP. No other adjustments.
Questions; The frequency dial. Do I use this to tune both the HP and LP ? Where would/does the dial end up after tuning both, if I do ? Which test tones would I use for each speaker, and again, am I able to actually set both LP and HP without a using a DSP ?
My fairing speakers are AA 602,(for mid/upper), and my lowers are Mmats PA 601,(mid bass). I can tune each pair separately because I have 2 sets of dials.
Old Nov 4, 2019 | 09:41 AM
Adenton528's Avatar
Adenton528
Use HP. With seeing that you have a 4110, I don't think that will be enough power for the Arc 602. Id recommend going with mmats in fairing too. Either way you choose, HP and about 100 hz as a starting point. No need for dsp at this point.
Also, did you install a BT355 line leveler?
Old Nov 5, 2019 | 07:06 PM
sbeamer's Avatar
sbeamer
I did not. Dave @ Mmats said I don't need them.
So when I originally installed the new amp, I did set the gain by using SMD distortion detector. Turned the frequency dial by ear. Now I have the SMD Crossover Controller. But was not sure what frequency to start with.
Truth be told, it sounds so much better than my previous amp. That one I did use the BT155 because it had NO adjustments. I only had the the Arcs then.
So, the Mmats I'm using for mid bass. Can I actually tune the higher frequencies out with the amp I have, or not so much?
Old Nov 5, 2019 | 08:05 PM
SBates08's Avatar
SBates08
Delete.
Old Nov 5, 2019 | 08:32 PM
Tailwind's Avatar
Tailwind
I did not. Dave @ Mmats said I don't need them.?
I'm gonna have to disagree w Dave. U need a flash, a BT355, or DSP to properly manage that Boom w aftermarket speakers.
T
Old Nov 5, 2019 | 09:28 PM
Adenton528's Avatar
Adenton528
T
Agreed
Old Nov 6, 2019 | 08:00 PM
sbeamer's Avatar
sbeamer
T
I did get the flash. Otherwise there's no sound out of the 2nd pair
HDK
Audio Systems
Nov 7, 2019 03:49 PM
haze324
Audio Systems
17
May 2, 2019 11:43 AM
Rockrivr1
Audio Systems
May 30, 2018 08:06 AM
harley.2006
Audio Systems
Jan 11, 2015 07:13 AM
JimmysFXDC
Feb 24, 2011 02:46 PM
