Amp output voltage
Old Aug 6, 2019 | 10:51 AM
Jpm1416's Avatar
Jpm1416
Default Amp output voltage
I might have something screwed up but cant figure out what I'm missing. I've adjusted gain with a multi meter before, but on this PBR300x2 I cannot get any measureable voltage on the speaker outputs. Anyone have any idea whats up? Its brand new fresh out of the box, its powered on, everything seems to be normal
Old Aug 6, 2019 | 11:24 AM
FrenchieM's Avatar
FrenchieM
If you can pack that amp back up and return it as it will only be a matywr
of time before you have magic smoke coming from it.
Old Aug 6, 2019 | 11:28 AM
InthewindMN's Avatar
InthewindMN
Are you using a 1K test tone? Meter set to AC volts? All switches on proper settings? Just a couple ideas.
Old Aug 6, 2019 | 04:36 PM
Jpm1416's Avatar
Jpm1416
Yep i did double check those.....
Old Aug 6, 2019 | 04:41 PM
Jpm1416's Avatar
Jpm1416
I realize its not the best, but its what I got at this point. I just need aome basic tunes I'm not looking to out do anyone. Just want to listen to some tunes now and then. I had a B52 it lasted about 5 weeks and died. Cerwin Vega wouldn't warranty it because I didn't have the serial number which was covered by the Velcro they supplied (couldn't get it off without destroying the sticker)
Old Aug 6, 2019 | 05:30 PM
InthewindMN
Turn on switch set to remote? Verify + and - on terminals and remote.
Did you measure voltage coming out of the head unit to the amp?
Old Aug 6, 2019 | 05:31 PM
SBates08's Avatar
SBates08
What bike is this going on?
And any other specifics you can give us.
Old Aug 9, 2019 | 12:21 PM
Jpm1416's Avatar
Jpm1416
FrenchieM was correct I should have thrown that POS is the trash. Amp is defective.
rain rider
Audio Systems
Jun 27, 2018 06:43 PM
slyedog
Audio Systems
May 9, 2016 09:45 AM
Benedetto
EVO
15
Sep 20, 2011 12:16 PM
joearizona
Jul 21, 2008 05:00 PM
hotrod351
EVO
May 1, 2007 01:38 PM
