Sena 20s + Sony XAV-AX7000 = a problem
Headunit and Phone via USB
Phone and Headset via Bluetooth
I have essentially the same setup In my Ram. the phone call comes in via Carplay, but I can switch it over to my BT headset via the source option on the iPhone call screen.
Has anyone be able to pair a wireless headset with the Sony ax-5000/7000/8000 or other similar head unit? I really want to confirm this prior to purchasing.
TIA
isn't this essentially the existing problem of the Boom/BT headsets/Freewire or WHIM?
you cant BT headset direct to the head unit
you have to use the WHIM or 7pin Din connected Freewire
you only get Car Play with a physical USB connection not BT (and NO Android Auto)
Currently I have my Android BT to the Boom and my SENA 20S EVO BT to my Freewire, so call routing occurs correctly (with contact info appearing on the screen and call routing to the headset)
Like you, I want better Android compatibility and Google maps/other is a must! (versus paying 120bucks per year for an out of date naviextras map)
BUT I also want to know can you run a long USB to the saddlebags with the SONY? as I don't want my phone on the bars (and Fat Head Cycles said in a YouTube that long usb extensions are a no)
TIA
take a look at BlkDragon answers to my earlier questions today. He is using a BT headset with his phone, which in turn is USB to his Sony XAV-AX70000
like you Google Maps or better is what I'm really after. Also the ability to pull up contact address details from my phone and Navigate to them (which my Boom doesn't seem capable of)
The Jukebox media compartment is a joke. its designed for 'my-first-smartphone' from 2012, and not the monsters we have these days...
I've got my Freewire, cables and USB flash memory for music, in mine. No chance of getting a Pixel XL in there (even if I took all that out!)
...agreed, the Boom! is WAY behind the times (even the new GTS which I certainly won't be coughing 2.5K for!)
while Crutchfield are correct in what they say, that's the exact same reason we cant BT headset to the Boom without the WHIM or the FREEWIRE, so we work around it by adding them or going via another route
Here's how I think it would be set it up:
EVO 20s connected to passenger / other bikers EVO 20s for intercom
Phone Connected to HU via bluetooth -OR- via USB for android Auto. AX5000/7000 can't be connected via blue tooth and USB at the same time.
CD interaction (I do use my CB for group rides with bikes that have it and no other comms, like a SENA)
Bike Intercom - not a big deal really. EVO direct intercom is better IMO.
Inability to connect a headset to AX5000/7000 for off head unit output.
Google Maps easy of navigation (with HU display via AA)
XM radio on the cheap ($40 for receiver instead of $400 for HD receiver) and this on has the high bandwidth receiver as well to support live traffic and weather alerts!
