CV B52 settings questions
Old Dec 26, 2019 | 07:08 AM
dawg's Avatar
dawg
Default CV B52 settings questions
2019 stock GTS head unit, Infinity Kappa 62ix, B52 amp....where should the cross over switch be, high pass, flat or low pass? Where should I start with gain and frequency switches? Going to be doing it by ear and/or the audio file that is posted. Still gotta get the BT355 prior to install but getting everything else set up. I assume I don’t mess with the settings on the BT355? Think I’m good with everything else. I was going to use a piggyback spade connector and grab remote power from the cig lighter, but I noticed that they changed the plug from what my 08 had so that won’t work without splicing so I’m thinking of grabbing the HD fairing power extension harness and appropriate mating connector and wire it to that.
Old Dec 26, 2019 | 08:41 AM
SBates08's Avatar
SBates08
Set the crossover to high pass and set crossover between 90-100 as a safe place to start. Can adjust up or down as needed when setting gains. Correct leave the BT355 settings as is.
Old Dec 26, 2019 | 09:00 AM
dawg's Avatar
dawg
Crossover adjustment starts at 40 and goes to 400 so 90-100 would be right around the low pass line which I colored red?
Old Dec 26, 2019 | 09:08 AM
SBates08's Avatar
SBates08
That is correct.
Edit: probably closer to 10:00 position.
Old Dec 26, 2019 | 09:10 AM
Juice's Avatar
Juice
Looks about right, play this 100hz test tone.
Set volume about half, set amp to high pass and play the tone. at the same time turn the xover pot clock wise till you hear the hum. that should put you right at 100hz. you can back down a tad if more warmth/bass is desired.
Juice
scott01
Aug 24, 2015 09:19 AM
tooloudman
Aug 28, 2012 02:48 PM
soundman
Apr 8, 2010 02:19 PM
Smitty0128
Jun 1, 2008 07:57 PM
Bldr1000
Oct 27, 2007 02:15 PM
