I've been running my setup now for coming up on 4 years and it's been great! Sony XAV-AX7000, Stinger SPX700.4, and Mmats PA601.4cx in the fairing.
I'm starting to contemplate adding speakers to my lowers... So, the age-old question is... what speakers do I add? Stick with Mmats? PA601? or a second set of PA601.cx?
Do people bridge the lowers? Why? What advantage? Would I then need 8 ohm instead of 4 ohm for the lower speaks?
Do I need spacers? If so, I won't be able to add speaks as I have a Heavy Breather AC and it's 0.5" from the current door on my lowers.
With the heavy breather AC you will not be able to run lower speaker pods. The only way would be to shorten the intake pipe and run a shorter AC filament
21524059[/url]]With the heavy breather AC you will not be able to run lower speaker pods. The only way would be to shorten the intake pipe and run a shorter AC filament
Thats good to know thanks. Is that with a grille? What if I run without a grille?
I ran lower pods with that breather. Have to have a flat grill that doesnt stick out at all, and it still did touch the grill a bit.
