8 ohm spkr on 4 ohm amp?
Old Apr 19, 2020 | 01:51 AM
desperado 66's Avatar
desperado 66
Default 8 ohm spkr on 4 ohm amp?
Ok i am ready to get back at my bag setup, looks like the recommended speakers for my lids are all 8 ohm speakers ,my amp is a ppi 1000.4 bridged to 500 per side at 4 ohms,each,
I have purposely kept all channels separate for a dsp.
there will also be 2 4ohm 10s but they are already on there own 1000.4 amp bridged to 500watts each... and two tweeters also already tied to the front 4 chnl amp with front tweeters so i cant double up for a 4 ohm load...
So how much am i losing by putting "8 ohm prv or ? sealed baskets" on a 500 watt 4ohm amp channel? if i am correct i will only be utilizing 250 watts each, not 500, correct? meaning half there potential?
Old Apr 19, 2020 | 03:00 AM
HD_noobie's Avatar
HD_noobie
Yes 250 watts, what speakers are you looking for that aren't 4 ohm?
Old Apr 19, 2020 | 12:45 PM
desperado 66
sealed back 6.5s
Old Apr 19, 2020 | 01:03 PM
c_mancuyas8's Avatar
c_mancuyas8
You have 2 ch left on the 1000.4 or only 1?
Old Apr 19, 2020 | 01:27 PM
desperado 66
currently the amp for the lids is bridged (1 and 2 500 watts) ( 3 and 4 500 watts) running 1 6x9 on each lid if I run it as 4 channel its ony 140 per channel I am trying not to waste any available wattage. the other amp same setup running 2 10s at 500 each, I was told not to run the 6x9 and 10 in same bag without sealing so thats why the sealed backs.
0 watts and 3 and 4 500 watts so 2 channels if run as 4 channel its on 140 per channel
Old Apr 19, 2020 | 01:32 PM
c_mancuyas8
The prv 6mr300seal @250w ea will be plenty of power!
Beyma makes a carbon fiber sealed back as well that would better utilize that power but it is considerably more expensive
Old Apr 19, 2020 | 04:02 PM
desperado 66
so if it is 8ohm do i just double the rms? when setting gains?
Old Apr 19, 2020 | 04:51 PM
c_mancuyas8
I think you might have something confused or I'm not understanding correctly but say you have 2 channels on your amp that are bridged 500w @4ohms if you take two 4 ohm speakers in parallel that would bring you down to 2 ohm, if you have two 8 ohm speakers that puts you at the correct 4 ohm load. This splits the wattage between the two speakers at 250w ea. I believe the prv sealed are rated at 150w rms the Beyma are 200w rms
Old Apr 19, 2020 | 04:55 PM
c_mancuyas8
as far as setting gains it has nothing to do with rms there's a sticky at the top to help with setting gains or you can do by ear. Keep in mind that the gain **** is not a volume ****.
Old Apr 19, 2020 | 09:11 PM
desperado 66
i dont know why it didn't occur to me to pair them left to right, senior moment,i quess lol
twp98
Audio Systems
Feb 25, 2016 04:05 PM
cycle crazy
Touring Parts
Feb 9, 2015 04:02 PM
shakak
Audio Systems
Nov 22, 2013 05:22 PM
Gunslingertom
Audio Systems
Jun 5, 2012 01:12 PM
customsoftail200
Dec 12, 2011 10:24 AM
